Need Help. Something Wrong No Power
Old Jan 26, 2008 | 03:44 PM
bahunt's Avatar
bahunt
Default Need Help. Something Wrong No Power
Need some help. All of a sudden my 2000 5.9 D developed a problem. When accelerating the D does not want to go much over 2000 rpm and barely wants to move. It doesn't seem like a transmission problem because it won't over rev. Pedal to the floor it will not go above maybe 2200 rpm. In park at idle it will revto redline tough.
Last night I changed engine oil and cleaned the throttle body by spraying STP cleaner as directed. Nothing alse has changed. I've tried adjusting the tv cable, doesn't seem to help. I tried adjusting the front band but never even got the wrench on it.
Any help would be appreciated.
Old Jan 26, 2008 | 06:52 PM
n8ech's Avatar
n8ech
Default RE: Need Help. Something Wrong No Power
bahunt:
How many miles on the rig??
My first guess would be a fuel pump on the way out. It can supply enough fuel for rpm runup with no engine load.
With a failing pump though, that is not the case when trying to propel the D.
Check fuel pressure and go from there.
Don
Old Jan 26, 2008 | 07:40 PM
bahunt's Avatar
bahunt
Thanks for the response. 63,000. Never thought about the fuel pump.
I was driving around trying to figure this thing out and finally threw a code. P1762 governor pressure sensor. Maybe it is the trans.
Old Jan 27, 2008 | 06:49 PM
n8ech's Avatar
n8ech
Bahunt:
I agree that there could be a tranny issue, but my guess is that since the motor can't make power the trans is not going to work properly either. I would still check the fuel pressure, and if thats ok then move on to the tranny.
Don
