some mod questions
Old Feb 9, 2008 | 01:56 AM
99fabtechdurango's Avatar
99fabtechdurango
Default some mod questions
is there anywhere that i can find billet fuel rails and bigger injectors for my 99 5.2? also would these be worth anything other than looks? i already have some mods done (look at my sig) any advice would be appreciated, and has anyone bought the new hypertech max energy tuner?
Old Feb 9, 2008 | 02:25 AM
mrwilliwizard's Avatar
mrwilliwizard
Default RE: some mod questions
ask a local independent garage they usually do it good.
Old Feb 10, 2008 | 01:43 PM
hydrashocker's Avatar
hydrashocker
Sorry dude. I don't see anything in the sig that would warrant larger injectors. You have a lot of building to go before you could even use them.
I don't even need bigger injectors yet and look at my sig. I even have more that are not listed.
Get rid of the TB spacer. They are the biggest waste of money for these motors. They don't work of MPI motors only carbureted motors.
Old Feb 10, 2008 | 01:51 PM
99fabtechdurango
im lookin for bigger injectors for a supercharger hopefully coming, its off a friend of mines dakota that wrecked and im looking for anything i can get that will maximize the power of the supercharger. also, which power programmer works bestwith n/a or forced fed motors?
Old Feb 10, 2008 | 02:25 PM
hydrashocker
Ok now you make sense. What I would do is this. You need to call the name of the supercharger's technical supportline, and ask them what they would recommend. Also make sure you tell them your altitude.
Next, I would get a custom computer flash from some big name like that of B&G or there are others. Forget the simple plug in type.
Old Feb 11, 2008 | 01:47 AM
99fabtechdurango
all right cool, thanks a lot. can i jut uy a computer thats been flashed already from an place like that or do i have to send them mine to flash it? cuz its my dd an i an aford to not have i running for longer than the weekend
Old Feb 11, 2008 | 10:38 PM
hydrashocker
If you do a replacement you need to have the dealer install it for you. It has to be flashed to your truck VIN and of course the dealer is the only one that can do it. I say HELL NO!!!! They will want to erase the custom flash and go back to OEM.
You can take out yours and send it to them next day. they will flash it and send yours back next day air. Total 2 days. Then just put it back in and skip the dealer.
Old Feb 11, 2008 | 11:31 PM
IndyDurango's Avatar
IndyDurango
Get your injectors here:
http://www.fiveomotorsport.com/
Get 24lb max IMHO or a set of new 19s.
If you find a nice (and less than $250) set of rails, let us all know. Nearly nonexistent for less than A TON OF CASH anymore.
HTH,
IndyD
