Anyone know what goes on this fitting?
Old Apr 1, 2008 | 11:00 AM
rgouette's Avatar
rgouette
Default Anyone know what goes on this fitting?
Please tell me this is why I'm getting P1494 & rough starting..?
Or at least what's supposed to go on this guy...
Thanks lads,
Rich
Old Apr 1, 2008 | 11:48 AM
OneBadKota's Avatar
OneBadKota
Default RE: Anyone know what goes on this fitting?
Kind of looks like a vacuum line.
Old Apr 1, 2008 | 12:17 PM
rgouette's Avatar
rgouette
thanks fer the reply.
lemme clarify, it looks like a Vacuum hose fitting.
Any thoughts?
Old Apr 1, 2008 | 12:26 PM
OneBadKota's Avatar
OneBadKota
P1494 (M) Leak Detection Pump Sw or Mechanical Fault Incorrect input state detected for the leak detection pump (LDP) pressure switch.
I looked at mine, the hose leads to under the fuse box.
Old Apr 1, 2008 | 12:31 PM
Parts/Service's Avatar
Parts/Service
Look under the battery for the purge solenoid. It should have 2 hoses coming off of it. One of these hoses goes to the fitting in the picture....
Old Apr 1, 2008 | 12:44 PM
rgouette's Avatar
rgouette
sweet cheeks of Budhha..
thanks fellers.
Rich
Old Apr 2, 2008 | 09:42 AM
rgouette's Avatar
rgouette
ok, so this is weird.
After hooking up a Vacuum line I found dangling on the engine(with a big split in the end), I reconnected it to the empty port on the intaqke.
Now, the truck runs terrible for the first few minutes...
When I first started it yesterday after reconnecting th eline, I couldn;t believe how badly it stumbled: I thought honestly that ti was going to stall...
It seemed to work it self out..
Could this mean that the 'pump' gizmo under the fuse box is bad?
I am baffled as to why hooking up the line made life worse....
Logic dictates that if I UNHOOKED the vacuum line, and left it open, that it would be back to where it was & would actually run better...doesn't make sense to moi...
ugh...
any suggestion is welcomed...
Old Apr 2, 2008 | 11:16 PM
n8ech's Avatar
n8ech
RG:
The system has to relearn the fact that this hose is now hooked back up which will stabilize the vaccum. If you need to speed the process up, do a battery disconnect reset by removing the negative cable and depressing the brake pedal for a min or so.
Then, hook back up and go for a drive. System should relearn its parameters and all should be fine.
Don
Old Apr 3, 2008 | 12:27 AM
rayjj's Avatar
rayjj
Mine just has a plug on that fitting. 2001 4.7
Old Apr 3, 2008 | 08:19 AM
rgouette's Avatar
rgouette
ray doode, does yours have the emission control system that mine does?
I was just told that since the truck came from MASS,that explains why it has this system(they're strict apparently)
Rich
