need tires... help
Old Apr 15, 2008 | 06:02 PM
marshman's Avatar
marshman
Default need tires... help
ok what are the biggest tires i can fit under my 99 slt with stock ride height? stock 15in rims as well
i'm really wanting 33's but i don't want rubbing... obviously...
so what are my options? and reccomendations would help too
thanks in advance
Old Apr 15, 2008 | 06:08 PM
deerang's Avatar
deerang
Default RE: need tires... help
I have almost new 31's all around, and I get very slight rubbing.. They are Goodyear Wrangler Silent Armour and the driver side rubs the end of the bumper when turning left..
so what I'm saying is you're pretty much stuck to 31's at stock height..
My goodyears are awesome on the road, very quiet, good in rain and fresh snow and slush, average on packed snow.. I havent taken them on a trail yet, so I dunno how they do in the dirt, etc.. But for all on-road good tire for the price..
People swear by the BFGoodrich All Terrains though, it's probably the most popular tire for SUV and light trucks out there...
Old Apr 15, 2008 | 06:26 PM
marshman's Avatar
marshman
i was actually looking at both of those on tire rack's website...
bummer that i couldn't even pull off some 32's, but at least now i won't have to have my speedo recalibrated for my tires.
also is there any difference between 31x10.5x15 and 235/75r15?
tire rack says there's 2 different oem sizes but i'm pretty sure it's just the metric equivalent. i find it strange, though, that they have 2 different prices for the "same size" so that's why i'm questioning it.
Old Apr 15, 2008 | 06:43 PM
deerang's Avatar
deerang
I'm sure you could give your tbars a couple cranks to clear 32's... I mean its only .5 inch more you have to clear..
the 235's are actually a smaller tire.. they are like 29 x 9.25 x 15.. i think it was a factory tire for a low model, or maybe its just a cheaper replacement tire... There is a D here at school that looks like its prolly on those 235's, without factory fender flares too, the thing just looks tiny... i think its a 98 sport model, very few options on it..
Old Apr 15, 2008 | 10:07 PM
marshman's Avatar
marshman
sports came with a small lift though, didn't they? i had a '00 dak sport 4wd (oem sizes)and it was a bit higher up than other daks around town on oem sizes. probably about 1-2 inches. durangos may be different though.
Old Apr 16, 2008 | 12:05 AM
deerang's Avatar
deerang
maybe it wasn't a sport, it was like a SXT, I don't know models (I have an SLT and I don't know what that even entails)... but it is the lowest model.. no fender flares, full cloth interior....
Old Apr 16, 2008 | 04:17 AM
marshman's Avatar
marshman
so i officially almost totaled it today when the smooth tread on the right rear decided to flake off leaving me with a 4-5 inch wide area of wires around the whole tire... lucky i stayed on the road. i had to hit the brakes and i just thought "well that's next on the list" (which it already is anyways) but it wasn't my abs screwing up... i was just shooting sparks because my tire locked up. little did i know that about 2 miles back, i was hitting the truck behind me with little rubber corn flakes.
as beat and ragged as my durango is, i'm suprised the spare actually holds air. the sidewall looks like it should at least have a slow leak as well. the spare rim is in pretty sorry shape from rubbing underneath because the cable holding it up wasn't as tight as it should have been. go figure. if i hadn't had any experience racing auto-x, i definately wouldn't have been able to save it and i'd be out approx $6400 (with all the work i've had done to it because of a very neglectful previous owner plus shipping from queens as well)
anyways, i'm definately ordering tires tomorrow
Old Apr 16, 2008 | 08:58 AM
deerang's Avatar
deerang
what are you going to be ordering?
Old Apr 16, 2008 | 10:11 AM
dwhisnant's Avatar
dwhisnant
ORIGINAL: marshman
Just a thought on the two OEM sizes. I noticed that tire rack didn't ask for 4x2 or 4x4 when I checked on tires for my 99 4x2. I know for sure it came stock with 235/75R15. Was that possibly the case then that the 4x4's all came with 31x10.5x15?
I've often wondered why the 4x4 looked a couple inches taller than my 4x2, but always chalked it up to suspension (which could play into it some too). But the tire alone would add an inch of height difference.
I may have to put some 31x10.5x15's on when my Pep Boys, Hankook passenger tires wear out.
Old Apr 17, 2008 | 11:39 PM
marshman's Avatar
marshman
i'm getting the bf goodrich all terrain t/a ko's
i've heard only good things about them and it's not a bad price either, so i'm set
as far as putting 31's on your 2wd... don't... there's really no reason to make a 2wd higher off the ground. if my d was 2wd, it would drag the frame. that's like lowering a 4wd. it doesn't make sense...
