Anyone try HHO?????
Old Jun 22, 2008 | 11:36 AM
dunc2092's Avatar
dunc2092
Default RE: Anyone try HHO?????
I currently have it in my 02 Durango 4.7 it's been running for 2 weeks and seems to greatly improved preformance and some increase in mpg.
It's a work in progress, I can post pics, and build data if anyone need it...
Old Jun 22, 2008 | 12:26 PM
Kensai's Avatar
Kensai
Give us more details concerning your improvements in mileage and power? Is it the same setup as the one that Hydra is talking about?
Old Jun 22, 2008 | 04:50 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i am working on a unit also it is not installed yet i am waiting for the epoxy to dry up and seal the unit and then i will run some tests and hopefully install it on monday, after which i will do a how-to for you guys and while i am testing my unit i will share the results when i get them
Old Jun 22, 2008 | 09:48 PM
DRO318's Avatar
DRO318
I would think six totenwater cells would be about right for this to perform at its best.
Old Jun 23, 2008 | 07:25 AM
shrpshtr325
THE ULTI-MOD
yea and you can tellme where in our enginge bay you are going to fit 6-10 of these things, their not huge, but still not alot of room under their for this stuff
Old Jun 23, 2008 | 06:01 PM
DRO318's Avatar
DRO318
First, It is just an Idea. But if you took time to use your brain... [sm=shootshoot.gif]If you remove the air filter housing in a 5.2 or 5.9. That would give you space. at that point one could change the air filtration setup to what you feel is best for your application. Now we have to figure a way to mount these things. You see, my older bro ran across the water4gas website and we wanted to try it on my Durango, but before I tried it I posted the Question. Will yall check out water 4gas.com. Now the gentleman on the HHO website had a Toyotafour cylinderwith six cells, so I figured it might take six to ten for a v-8.[sm=confused06.gif]
Old Jun 23, 2008 | 07:24 PM
dunc2092's Avatar
dunc2092
these are the pics. of my setup
I have tried all the different vacuume ports and the throttle body seems to work the best see photo.
there is a definate improvement in idle and power bue I don't have enough miles to notice an improvement.
My system is modeled after water 4 gas with perforated 316L (low carbon surgical) stainless steel.
26oz of distilled water and 1/2 teaspoon baking soda seems to be the combination.[:-]
I'm unable toattach my pics! nothing is working tonight.....
if you want to see them i'll send them ....
Old Jun 24, 2008 | 07:54 AM
shrpshtr325
THE ULTI-MOD
i will also attach my pics later when i get them onto my computer, i made mine out of a half gallon plastic jug and was able to fit it in just forward of the air intake, pics and write up to follow
Old Jun 24, 2008 | 09:20 PM
DRO318's Avatar
DRO318
The water4gas sitee-books state thatyou would produce more hydrogen with multiple cells than just one. This is why I plan to try more than one cell. I mean lets see if someone has one cell and does not see a lot of a difference, then what should they do. Try more cells. like they did in the E books. If they got better results why can't we?
Old Jun 25, 2008 | 08:18 AM
shrpshtr325
THE ULTI-MOD
we could, but i dont want to take out my stock air box, so i dont have alot of room around the engine to install one, so im starting with one(installed on monday of this week) and ill see what the results are and then report back
