It won't start...0 RPMS while cranking. Help!
Old Jun 25, 2008 | 10:17 AM
DurangoAndy's Avatar
DurangoAndy
Default It won't start...0 RPMS while cranking. Help!
Hey everyone,
I've been going crazy trying to get my Durango started once again. When I go to start it, it just cranks and cranks, but there are no RPMs (either on the tach or from a scanner). The check engine light is not on, so there are no codes to help.
Here's what I've tried:
[ul][*]New Crank Position Sensor (okay, 2 new sensors just in case).[*]New Cam Position Sensor[*]Checked fuel pressure - 45 - 50 psi.[*]Noid light shows the injector firing once when you start to crank.[*]Backprobed the crank sensor and can see that it's giving a signal when cranking (0- 5 volts)[*]Checked that there is 5 volts supplied to the sensors from the PCM when the ignition is on.[*]Checked all the fuses and links - all good. Swapped the links around, just in case.[*]Battery is charged with 12.6 volts.[*]Checked and cleaned all the ground staps.[/ul]
Do you guys have any ideas at all? I can't think of anything else to try!
-Andy
Old Jun 25, 2008 | 12:12 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default RE: It won't start...0 RPMS while cranking. Help!
idk for sure but maybe you could check the coils
Old Jun 25, 2008 | 03:43 PM
DurangoAndy
Yeah, that's the one thing I haven't checked yet. Since there are 8 separate coils, you'd think that enough would be working to get it started at least.
Old Jun 25, 2008 | 07:48 PM
hydrashocker's Avatar
hydrashocker
You always check for spark and fuel first.
Second, What spark plugs are you running?
Third it might be a relay/fuse.
Old Jun 26, 2008 | 07:22 PM
DRO318's Avatar
DRO318
I am with hydra spark plugs andyour coilscan make a difference. I once ran bosch in mine and had the same problem after 400 miles. GO Platinum 4's.[sm=boosign.gif]
Old Jun 26, 2008 | 10:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
Does the cluster show no bus????
