P0036 02 Durango 4.7
Old Jul 2, 2008 | 06:18 PM
explrcnvrtbl's Avatar
explrcnvrtbl
Default P0036 02 Durango 4.7
Hi, we have a P0036 DTC on our 2wd 2002 Durnago 2wd 4.7L automatic
I have talked to a couple sources and I think it is the Driver's side after cat sensor, however, 1 of the sources I talked to said it was completely opposite and was the passenger side before cat....
so i am not sure what i am dealing with....
a source also told me that there is no P0036 on Dodge? that there is only a P0032 or a P0037? any help on that?
I borrowed a Actron code scanner from autozone
the P0036 said that it is a bank 1 sensor 2
bank 1, sensor 2 is the driver's side after cat according to the service dept @ my local dodge dealer.....
is P0036 a valid code? and is it bank 1, sensor 2?
Old Jul 2, 2008 | 07:42 PM
explrcnvrtbl
Default RE: P0036 02 Durango 4.7
bump
Old Jul 2, 2008 | 10:38 PM
explrcnvrtbl
please help
Old Jul 3, 2008 | 12:14 AM
explrcnvrtbl
REALLY NEED THIS INFO! ASAP
Old Jul 3, 2008 | 01:54 AM
explrcnvrtbl
TTT
Old Jul 3, 2008 | 03:07 AM
explrcnvrtbl
again, i really need help on this!
Old Jul 3, 2008 | 08:39 AM
jeff66's Avatar
jeff66
If p0036 were not a valid code you would not be reading it. You seem to be questioning wether or not bank 1 sensor 2 is indeed the driver side after the cat even after the dealer verified what i said. here's another way, unplug that sensor, you will get a p0036 plus additional codes and they will also say bank 1 sensor 2.
whoever told you that Chrysler does not use p0036 apparently does not have the correct info, i havea haynes manual for durango 00 thur 03 and it does not list a p0036, this is not a publication produced by Chrysler and does not contain all data. so i had to look it up else where.
Old Jul 3, 2008 | 07:32 PM
explrcnvrtbl
i did question it because of the varying information i was told by several parts stores [even a very knowledgeable one that is very good, (but not all sales associates are equal however)]
i wasn't questioning you, in fact, it was your information that gave methe original info, and what i was trying to fight the parts store guys for.... your information when i went to dodgeto confirm.... i actually had to help theparts guy out, he made a tech go look it up
i am actually glad to hear that is is a p0036 and it is a valid code....the autozonei went to said it isnt a valid code andanother store saidhe wouldnt trust an autozone code reader.....
i am the kind of guy that isnt a doubtful person, but i need to make dang sure i know what i am getting into.....
JEFF, I THANK YOU AGAIN FOR ALL YOUR HELP ON THIS
Old Jul 3, 2008 | 07:57 PM
jeff66's Avatar
jeff66
No problem, you just sounded unsure. What is the model number of the scanner you got from autozone? I have a Actron CP9180 bought at autozoneand can acually read the voltage of the O2 sensors with it.
Old Jul 3, 2008 | 08:18 PM
explrcnvrtbl
i dont know the model number.... its jsut something i walked into the store and said, hey do you have one i can borrow for 5 minutes and they let me go outside with it, i cleared the code, and went back inside....
they said they rent them out for a $165 deposit..... basically, if you steal it or break it, you bought it... but when you bring it back, they give you back your $165
