Driver seat issue
Old Jan 7, 2010 | 02:15 AM
  #51
tm985's Avatar
tm985
Originally Posted by shrpshtr325
yup pull out the wrenches and get to work, make sure you got noowhere to go for a while in case you have problems
damn that was not the answer I was hoping to get
I'm afraid that once i take it off I'll never be able to put it back together properly.
Old Jan 7, 2010 | 08:59 AM
  #52
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you really shouldnt have any problems its very straighforward, and there are only 5 bolts which will only fit into certain holes so the chances of screwing up are very low
Old Jan 7, 2010 | 02:25 PM
  #53
tm985's Avatar
tm985
Thank you sir good to know
Old Jan 7, 2010 | 06:15 PM
  #54
shrpshtr325
THE ULTI-MOD
keep in mind the seat cover does fit on the cushion pretty tightly so be careful not to damage/tear it taking it off
Old Jan 8, 2010 | 12:40 AM
  #55
tm985's Avatar
tm985
What about the fact that it's a power seat? wouldn't that be a can of worms as well?
I've thought about maybe the next time I gotta take it to a mechanic that I'll just ask them to tighten it up for me or something if they get a chance and throw some extra money at them. I'm going to take a look at it when the weather gets a little nicer but for now just dealing with it.
Old Jan 8, 2010 | 09:12 AM
  #56
shrpshtr325
THE ULTI-MOD
the power seat is what causes it to wear and rock to begin with, and its actually not bad to take out of the truck regardless of it being a power seat
Old Feb 21, 2010 | 10:08 PM
  #57
leonardo's Avatar
leonardo
I put in a small section of pipe as a spacer and the slide is gone
Old Feb 23, 2010 | 02:32 PM
  #58
tm985's Avatar
tm985
I was thinking about doing that too, how did you do it and where???
Old Mar 29, 2011 | 01:02 PM
  #59
304073's Avatar
304073
@Kensai: THANK YOU, THANK YOU. My 2003 Durango had the rocking seat problem, dealer quoted me $1,000+ to fix it. Followed your instructions, took me just under two hours (you're right those rear bolts are a PITA to shift, rest of the time getting the spacers to fit exactly, made from offcuts of plastic water pipe) and total cost $42, for the tools. Seat is now perfect.
Just wanted to let you know the info is much appreciated and has been successfully used
Old Mar 29, 2011 | 06:03 PM
  #60
Kensai's Avatar
Kensai
Great to hear. Just hope that plastic will hold up for you over time! The spacers I got from homedepot looks like carbon fiber type washers so I know they will never fall apart on me.
