'99 Durango windshield washer pump
Subscribe
Jul 13, 2008 | 08:08 PM
Does anyone know which fuse provides power to the windshield washer in a '99 Durango 5.2L? None of the fuses in the fuse box seem to control it. A test light says that no power is being delivered to the connector to the pump, so it is either the switch (turn signal/windshield wiper multi-function switch) or a fuse, hopefully the latter. The wipers work. Thanks.
Reply 0
Feb 2, 2009 | 08:46 PM
I have a 2nd gen with the same problem. Did you ever find the fuse or what the problem was?
Reply 0
Feb 2, 2009 | 10:23 PM
Ck fuse number 5 in the juction block, and ck see if both front and rear are inop. If both are not working, then the problem maybe in the CTM central timing module.
Reply 0
Feb 3, 2009 | 08:10 AM
I have two fuses that say front hi/lo and front on/off. i pulled both of them one at a time and nothing works without both fuses in place. However, i didn't check the fuse to the rear but the wipers work fine. i noticed the fuses are larger than a typical 12-20 amp fuse. Do you think that something is out inside the fuse because you can't tell If anything is wrong with the fuse by looking at it.
Reply 0
Feb 3, 2009 | 10:20 AM
You have a 2004 or newer durango. Ck fuses 1,2 or3 and the relay. The washer motor is controlled by the front control module.
Reply 0
Feb 3, 2009 | 03:30 PM
2006 Durango
Reply 0
Feb 3, 2009 | 03:34 PM
Also which fuse box should i be looking in? there is one by the foot panel on the driver's side and 2 more next to the engine.
Reply 0
Feb 3, 2009 | 07:43 PM
It would be in the PDC box, under the hood.
Reply 0
Feb 4, 2009 | 09:31 AM
Is that the one closest to the firewall and am i still checking the same fuses you mentioned before?
Reply 0
Feb 4, 2009 | 01:14 PM
If you don't mind can you send me your email address in a pm so i can take pic of my fuse boxes with my phone then send them to you.
Reply 0
