2002 Durango AC blows cool not cold
Old 07-25-2008, 11:37 PM
Momstruck's Avatar
Momstruck
Momstruck is offline
Default RE: 2002 Durango AC blows cool not cold
What exaclty is evacuated on the ac system, what does that do for it? Also I put an a/c guage on my line today and it said the psi were to high...to take it to a mechanic? But the lines were cold.
Thanks
Old 07-25-2008, 11:44 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
It means to extract the freon and oil from the system. What was the pressure???
Old 07-25-2008, 11:47 PM
Momstruck's Avatar
Momstruck
It read 47 to 49 psi.
Old 07-26-2008, 12:02 AM
hydrashocker
What was the outside temp at read???
Old 07-26-2008, 12:04 AM
Momstruck's Avatar
Momstruck
92 in wonderful texas with about 60% humidity
Old 07-26-2008, 12:10 AM
hydrashocker
It should have been about 52 psi on the low side.
I wonder if they installed Synthetic freon for colder air.
Also being that low would do it.
Old 07-26-2008, 12:16 AM
Momstruck's Avatar
Momstruck
Really....so I should charge it up to 52 psi and it will be fine? Or should I do the evacuate thing and have it refilled?
Old 07-26-2008, 12:22 AM
hydrashocker
Well the e-vac pulled out air and drained the system then freon and oil was added to replenish it. The e-vac only vacumed the system (by law they can't just releaseany into the air) and after this your pump can grasp it and start working correctly. But at full capasity which you were not at then yes you would refill to that PSI with weather conditions as you explained but they change by temp and system.
Old 07-26-2008, 12:27 AM
Momstruck's Avatar
Momstruck
one more thing.....usually how much does it run to evac the system?
Quick Reply: 2002 Durango AC blows cool not cold
