Replace Cat Converter????
MG:
What year, model, engine, and how many miles on your D???
Convertors rarely go bad. Usually the 02 sensor croaks, or there is an issue with its wiring.
If is does turn out to be a convertor, they are warranted for 8yrs and 80k. Hopefully that will help if needed.
Don
Don
Sorry about that! It's a 01 Durango 4.7 with around 98,000 miles on it. Check engine light has been on for a while now. Checked the codes and I'm getting a P0420. I've called my local muffler place to see what it would cost to replace the cat converter, but if there's a cheaper option that would fix the problem, I'd rather do that!
MG:
As you may already know, the code indicates calalyst efficiency below threshold.
Since the downstream 02 is what monitors this, I would go in with a new downstream 02, and see if that takes care of it.
While it is possible that your convertor is bad, they rarely do unless there is some type of engine fuel system malfuction which ends up putting alot of unburned fuel into it.
You can go with a Bosch unit from your local AZ, or spend a few more bucks and get OEM from Dodge.
I would think that either one will be fine.
Don
Don
PO420 is the cat.Dodges do seem to go through cats rather easily. The converter can be bad and not broken up inside yet.First it will melt down and clog up inside,then it will start to break apart.98,000 miles is not un-common to see the cat bad.
I would replace it and also have the rear O2 tested to see how it is reading,but more likely the cat.An exhaust shop should be able to replace this for about $250-$300 installed.Best to shop around.
Good luck man.
Good luck man.
Trending Topics
Just look under the vehicle.It will either have 2 pipes coming into the front of it or one.
Whats the year and engine size?
