2000 dango
Old Aug 22, 2008 | 07:08 PM
jmetz1969's Avatar
jmetz1969
Junior Member
Default 2000 dango
will not start with out giving it gas
some thing in the fuel system? when it does start runs rich fuel reg?
I think this is common becuse my 93 ram does this too just haven't
fixed that yet when it starts you have to keep it running battery is old
Old Aug 22, 2008 | 07:14 PM
n8ech's Avatar
n8ech
JM:
Are you getting any check engine lights???
How old is your battery???? Our Durangos are extremely sensitive to a failing battery. Have it load tested, and if it shows the least bit flaky, or is more than 4 years old replace it.
Once it starts, will it stay running w/out keeping your foot on the pedal???
Don
Old Aug 22, 2008 | 07:22 PM
mlkmgr's Avatar
mlkmgr
could be a number of things. off top of my head:
failing fuel pressure switch--clogged fuel filter--clogged fuel injectors.
try some fuel injector cleaner to start--sea foam works well.
have your fuel pressure checked.
good luck...
Old Aug 27, 2008 | 06:45 AM
wordsworth's Avatar
wordsworth
test ur battery first , it might be about to die..
and as my friend Don said, the D is very sensitive to old batteries.
regards,
