Blinkers and brake lights not working...Please help!
Old Aug 26, 2008 | 10:03 PM
jaysquared's Avatar
jaysquared
Default Blinkers and brake lights not working...Please help!
My blinkers and brake lights suddenly stopped working last week while driving back from a camping trip. I haven't tried to look at the fuse to see if its blown because my D is my part time car so I wasn't in a hurry to get it fixed. So i'm wondering what could be wrong with it. I should just check out the fuse first but if anybody has had experience with this same problem and know what I need to fix that would probably save me some time instead of trying to figure it out myself. Thanks for any input!
Old Aug 27, 2008 | 10:52 AM
hydrashocker's Avatar
hydrashocker
The fuse box is on the drivers side, in the cab where you open the door on the dash, under the turn signal switch.
The fuse is 15 AMP if I remember right.
Were you towing????
Old Aug 27, 2008 | 02:23 PM
jaysquared's Avatar
jaysquared
Thanks for the reply Hydra..Yes I was towing my boat.. I'm guessing that probably had something to do with it going out.. I did check out the fuse for the turn signals in fact I checked them all and none of them have a broken connection.. Switched out the fuse for the turn signal with the spares that came with the car and still not working. Any other suggestions?
Old Aug 31, 2008 | 11:08 PM
jaysquared's Avatar
jaysquared
Still can't figure out a fix for this.. Anybody have any suggestions?
Old Sep 1, 2008 | 12:50 AM
hydrashocker
The trailer has a short in it so it blew your vehicle fuse.
Look under the hood in the master fuse box (drivers side) and you should have another fuse called the trailer lights or something like that. Double check that.
The last place I would go would be the flasher located in the cab fuse box. It's the one shaped as a box toward the bottom I think.
Old Sep 1, 2008 | 01:51 PM
DRO318's Avatar
DRO318
my flasher was under the bash behind the fuse box. I pulled it out using some pliers
Old Sep 9, 2008 | 10:40 PM
jaysquared's Avatar
jaysquared
Thanks Hydra got that all fixed now.. it was the fuse in the main box that was blown. Sorry for being a noob about this but thanks for all help.. much appreciated.
