Remove front axles better mpg?
Old Sep 18, 2008 | 07:59 PM
thumper1's Avatar
thumper1
Thumbs up Remove front axles better mpg?
Got a question...I have a 98 Durango 4x4 with bad cv boots that are leaking. So here is what I am thinking... I know I have to replace the boots and or the axles, I it possible to remove the 2 axle shafts completely and run with out them? Is the load of the vehicle carried on the front hubs and not the axles? If so I would like to just take them off and possibly save some mph not having the front diff. turning all the time.
Ok you experts, so what do you think? I don't take it off road anymore and it would save some money in a couple different ways.
Old Sep 18, 2008 | 08:08 PM
Neo1130's Avatar
Neo1130
No... Just no... Multiple problems with that... No...
Old Sep 18, 2008 | 10:11 PM
n8ech's Avatar
n8ech
Thumper:
Two reasons not to do this.
#1. There will be no measureable change in mpg. The majority of the 4x4 systems weight will still be there.
#2. The front bearings depend on the pressure of the axleshaft being installed to keep the bearing from self destructing.
You might make it a block or two if you try to drive w/out the shafts installed.
Don
Old Sep 18, 2008 | 10:52 PM
thumper1's Avatar
thumper1
thanks for the input quys, not such a good idea.
So how hard is it to put new or rebuilt axleshafts in. I have heard from very ez to very difficult. How many have exchanged these out?
I'm fairly mechanical but could use some helpful hints.
Thanks
Old Sep 18, 2008 | 10:54 PM
Neo1130's Avatar
Neo1130
Don
I have seen a case in an Audi where the guy JUST installed new wheel bearings. While he had his front axles out of the car, he pushed his car a total of 20 feet... Needless to say, he needed to do the wheel bearings yet again... At $160 a peice, they ain't cheap... Good thing they are cheap for the D!
Old Sep 18, 2008 | 11:03 PM
Neo1130's Avatar
Neo1130
It shouldn't be too hard... Just get a manual...
Old Sep 19, 2008 | 10:09 AM
hydrashocker's Avatar
hydrashocker
It is easy.
Use the search to located at the top of the page to get info. I did it and here is a link with instructions.
https://dodgeforum.com/forum/showthr...ghlight=joints
Old Sep 21, 2008 | 09:19 AM
nim81's Avatar
nim81
i took my axle shafts out and havnt had a problem (YOU HAVE TO SEPERATE THE AXLESHAFT FROME WHERE IT BOLTS THROUGH THE HUB!!!!) leave the spline thing on the hub i have my whole front diff taken out and no mpg gains! havnt had any problems with this and its been about a year now with no 4x4
Old Sep 21, 2008 | 09:29 AM
nim81's Avatar
nim81
oh btw~ if you do take the spline part out of the hub after redoing ball joints and a 12 pack of budlight this will happen i made it 15 feet out of the driveway broke my hub/spindle/steel braided brake line/ and my heart boo hoo
Old Sep 21, 2008 | 12:08 PM
Neo1130's Avatar
Neo1130
Yet another reason you don't touch them...
