CODE: P0340 & P1391 - CMP/CKP Location
Old Nov 1, 2008 | 05:40 PM
  #21
DRO318's Avatar
DRO318
Yeah real nice dude. 5 stars
Old Nov 2, 2008 | 12:56 AM
  #22
datacop's Avatar
datacop
Originally Posted by Mean Green
I enjoy your writing style Data.
Thanks. I enjoy writing and trying to make it non-boring sometimes by interjecting a bit of humor and a touch of story telling. I also favor spell check quite a bit
Old Nov 2, 2008 | 09:23 AM
  #23
Mean Green's Avatar
Mean Green
Wuts this spel chek yu speek uf?
Old Nov 2, 2008 | 03:05 PM
  #24
hydrashocker's Avatar
hydrashocker
^ lol ^
Old Apr 7, 2010 | 01:19 PM
  #25
Shadow96's Avatar
Shadow96
Default after repairs, then what?
Question,
After you repaired the sensors, did your truck run smoothly. Or did you have to have the timing tweeked. Im asking because I had a guy replace my sensors etc and now the truck takes a while to start and I cant drive over 60mph. When it gets to 58mph it starts shaking and bucking...any suggestions. I took it to Oreillys to do a system check and it wont put out any codes now...Can anybody help me.
Thanks
Old Apr 7, 2010 | 10:27 PM
  #26
hydrashocker
You need to give us the the year, motor, and 4X4? Also what you have done already?
Old Jun 29, 2011 | 12:39 PM
  #27
Wite Liun's Avatar
Wite Liun
My time has come for this ever so popular task. I've found thus far: seems AC Delco sensor is in block now. It has a different spacing on the bolt down flange than a "standard" replacement sensor (crank sensor) So to cover **** will go with whats there. Removing harness plug is easy in print but not so in a life time achievement factor.Will return as progress moves forward
Old Jul 9, 2011 | 02:33 PM
  #28
Wite Liun's Avatar
Wite Liun
Sprayed ..scraped and ended up twisting rather than screwdriver pry it out..took some time but10 min to put new in. Also had enough with limited room so I removed inner fender (plastic) have 2 pics of new installed for location purposes.
Thanks for all the postings in here to get me thru
Smitty
