02 durango drivers side seat warmer
Old Oct 25, 2008 | 02:09 AM
02 4.7 Durango's Avatar
02 4.7 Durango
Default 02 durango drivers side seat warmer
has any one experienced the driver side seat warmer inop, both low and high settings.
Gibson single exhaust, 180T, Personal made front grill, Custom made air funnel, home brewed short ram. IAT relocated, TPS modified, autolite 3923 SPs.Bilstein HD, 140,000+ miles still running smooth and strong have had no major problems.
Old Oct 25, 2008 | 11:03 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yes
the switch just flashes hi when you turn on either setting there is an open circuit(i think )in it which just means that one of the wires are broken inside and the circuit isnt completeing you need to replace the heater element which is attached to the marterial that gives the seat its shape so its really kind of expensive so im not bothering with it
Old Dec 5, 2008 | 02:19 PM
brighteyes818's Avatar
brighteyes818
Default Seat Heater
Hi,
How do we know it's not just the switch? Thanks
Old Dec 6, 2008 | 11:22 AM
Mean Green's Avatar
Mean Green
If you have a voltmeter you can check voltage drop across the switch. it shouldn't be more than .1 volt.
Everytime I've seen this issue come up it is the heating element that has the problem.
Old Dec 6, 2008 | 09:14 PM
shrpshtr325
THE ULTI-MOD
exactly, or at least that is what i did for it i also managed to switch the switch with the one from the passenger seat to make sure that it would work the passenger heater and it did on mine, if you know what you are doing you could try to do that too
