HELP 2000 5.9l - Replaced TPS & STILL SURGING!
Old Nov 24, 2008 | 04:43 PM
drsells's Avatar
drsells
How can I check if it is a bad circuit???
Old Nov 24, 2008 | 10:19 PM
Mean Green's Avatar
Mean Green
The circuit sounds fine. Something in the circuit is bad. Usually it is a dead spot on the TPS that causes this problem and I really think you just got your hands on a bad one. Take the new one back and exchange it just so you can avoid throwing parts at it.
Old Nov 25, 2008 | 06:49 AM
HankL's Avatar
HankL
if it does it on hills with cruise control
then it sounds like the tcc is unlocking
due to the PCM computer telling it to,
i am not sure about a model yr 2000
but the key on/key off/key on
trick may let you see your codes
perhaps in the digital trip odo readout
or perhaps with a blinking Check Engine light
... have you done that or had the codes read at an auto store?
Old Nov 27, 2008 | 07:56 PM
drsells's Avatar
drsells
Ok, the good news---I figured out what was wrong...
The bad news----and I do feel like an idiot about this ..... I put the replacement TPS in upside down...lol....switched it around and voa la----works great!
Old Nov 29, 2008 | 09:01 AM
Mean Green's Avatar
Mean Green
Well you live and you learn I guess.
Glad you found your self made problem.
One more smiley for good measure.
