HELP 2000 5.9l - Replaced TPS & STILL SURGING!
Old Nov 21, 2008 | 06:18 PM
drsells's Avatar
drsells
Default HELP 2000 5.9l - Replaced TPS & STILL SURGING!
I had the problem where my engine would surge 100-200 RPMS. It initially just did it with cruise control and now it does it other random times to...typically not during acceleration, just when maintaing a steady speed.
I replaced the TPS (got it at autozone). Seemed pretty straitforward to install. Problem though is that it is still doing the exact same thing...
What could be causing this??? Any ideas???
Old Nov 21, 2008 | 07:27 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
did you reset the PCM after install?
disconnect the negative battery terminal and then hold the key to the start position for 30 seconds (or overnight) and then start it and stop it 3 times, on the third time let it idle for a couple minutes then take it for a drive and it should relearn the parameters for the new sensor see if that helps
Old Nov 21, 2008 | 07:29 PM
drsells's Avatar
drsells
Yes, we did that. Should I try cleaning the TB??? All that I did before was take that TPS off and popped the other one back on...seemed TOO easy! lol
Old Nov 21, 2008 | 07:31 PM
shrpshtr325
THE ULTI-MOD
hmm yea and how long since you have done a full tune up? plugs wires cap rotor air filter? maybe try some of that stuff if you do plugs go champion, either stock copper, or i have heard good about the truck plugs (just NO platinum these engines dont like them)
Old Nov 21, 2008 | 07:33 PM
drsells's Avatar
drsells
I just picked up a new air filter today----haven't had a tune up yet---just got the truck last month 130k miles on it --its a 2000 5.9 SLT 4x4----got it for 2500---not too shabby
Old Nov 22, 2008 | 03:52 PM
Mean Green's Avatar
Mean Green
Maybe you have a vacuum leak. It's not unheard of to get a bad part as well. Look into exchanging the TPS you have for a new one.
Old Nov 22, 2008 | 05:48 PM
drsells's Avatar
drsells
How would I know if I have a vacuum leak?
Old Nov 22, 2008 | 06:12 PM
Mean Green's Avatar
Mean Green
Take some carb cleaner around suspect vacuum lines and spray a little over them with the engine running. It will cause the engine to rev up if there is a leak.
Old Nov 23, 2008 | 01:27 PM
HankL's Avatar
HankL
what speeds and driving conditions does the surging happen at?
a slipping torque converter lockup clutch (TCC)
causes about a 150 to 250 rpm change
the TCC can slip due to worn out frictional facings,
or too little pressure,
or bad solenoid action,
or bad electrical circuit to the solenoid on the valve body,
or most simply .... a bad ground connection that affects the entire circuit and PCM computer
Old Nov 24, 2008 | 04:42 PM
drsells's Avatar
drsells
It is pretty random when it happens, but it seems to happen most when I am applying a moderate amount of thrust to get up a hill, etc.
Example, when the cruise is on and I am driving down a level road, it really doesn't do anything...if I came to a hill in the highway, as it begins to apply more power, that is when it fluctuates by 100-200 rpms.
Now, if I were to really push down on the accelerator (gun it), it does not do this at all and applies a strong, steady thrust.
