2000 - Strong Vibrations/Pulls to the Left above 65MPH
Old Nov 24, 2008 | 04:46 PM
drsells's Avatar
drsells
Default 2000 - Strong Vibrations/Pulls to the Left above 65MPH
Hey guys, I have a 2000 5.9L
It has really strong vibrations (can feel it in the steering wheel and even in the seat) when it goes above 65MPH.
Also, it really pulls hard to the left and takes a lot just to keep it going straight.
This is what I have done so far and it has not phased the problem at all:
1) Replaced Left and Right Front Hub Assemblies
2) Had All Wheels Aligned
3) Checked Tires and they are good
Any ideas????
Old Nov 24, 2008 | 10:10 PM
Mean Green's Avatar
Mean Green
Look at all of your suspension components. Something up there is no good. Check for anything loose. Ball joints, tie rod ends, etc. Also make sure your brakes aren't dragging.
Old Nov 25, 2008 | 02:06 AM
drsells's Avatar
drsells
Do you think it is the ball joints??
How can I know for sure??
I did notice that in parking lots, when I am making hard turns (wheel hardover), that it feels like there is some kind of slipping or something....Kind of like a jump....is that the ball joints then??
Old Nov 25, 2008 | 08:46 AM
Duranged408's Avatar
Duranged408
Describe first how this comes about... IE- under accelleration, coasting, vibration slowly intesifies, etc etc
Since you ruled out hubs and alignment i want to say these (1-2 being most)
Driveshaft/U-joints
Lower ball joints
Tire-(balanced weights both sides/separated belt/bent rim/etc)
Old Nov 25, 2008 | 12:03 PM
Mean Green's Avatar
Mean Green
All I'm suggesting is to diagnose the problem first then replace as necessary. If you lift the D and touch between 2 components ie ball joint and control arm and wiggle the tire you may feel some play. If there is play replace the component. I suggest moog for everything up front.
Old Nov 26, 2008 | 01:25 PM
drsells's Avatar
drsells
Ok, great news---found out what it is!!
Out of curiousity, I wanted to see what would happen by rotating the two front tires.
Now, it pulls to the right instead of pulling to the left
After further checking out the now passenger side tire, it appears that one of the belts inside had busted. This would definately explain the pull and the vibration---new tires on the way from TireRack.com !!!
Thanks guys for all of your help!
Old Nov 27, 2008 | 12:15 AM
Mean Green's Avatar
Mean Green
Good find.
