dash warnig lights flash on and off
Old Jan 15, 2009 | 12:03 PM
14vanhalen's Avatar
14vanhalen
Question dash warnig lights flash on and off
The abs and e-brake light both came on steady on my 2000 durango ...and now the go out randomly. Is this some code?cnat understnd why both would came on Anyinsight on this would be a great help
thanks
Old Jan 15, 2009 | 09:42 PM
Mean Green's Avatar
Mean Green
I belive you are looking at a new wheel speed sensor.
Old Jan 15, 2009 | 11:32 PM
hydrashocker's Avatar
hydrashocker
Yup!
It's located on the top of the rear axel.
Old Jan 16, 2009 | 03:35 PM
14vanhalen's Avatar
14vanhalen
I just replaced it a little over a year ago ....
Old Jan 16, 2009 | 10:04 PM
master tech's Avatar
master tech
Site Moderator & Tech
When was the last time the inspection cover was removed and serviced? The reason I ask is because on LSD or Trac-Loc diff's, there are clips that hold the clutches together and when they break, the clip drop into the oil and the ring gear will pick up the clip and start making some noise. You also have a tone ring next to the ring gear, and if metal gets on the tone ring it will damage the ABS sensor or cause it from reading a RPM signal from the tone ring, kick the lites on.
Old Jan 17, 2009 | 09:21 AM
14vanhalen's Avatar
14vanhalen
I changed the diff oil on Jan 2 ...found nothing ....I'll replace the sensor and see what happens
