Strange noise....
Old Jan 16, 2009 | 10:11 PM
Durango03's Avatar
Durango03
Default Strange noise....
Ive noticed the last couple of days a rather loud noise that sounds like alot of air escaping. I thought at 1st it was my NEW tires I just bought, but when I open the hood it gets louder. I am thinking it may be the fan everyone keeps talking about. Do you think my extended warranty will cover this?
Old Jan 16, 2009 | 11:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
The fan clutch maybe the noise or maybe water pump. As far as warranty, You need to ck with the dealer.
Old Jan 17, 2009 | 11:24 AM
Mean Green's Avatar
Mean Green
Is this like a hissing sound?
I would take a (cheap) hose and cut a 2-3 foot length of it and use it as a stethescope to trace the location of the noise if you're having a hard time tracking it down.
Old Jan 17, 2009 | 03:07 PM
hydrashocker's Avatar
hydrashocker
While the engine is cold open the hood and DO NOT START the motor. Try to turn the fan. It should take a little force to move it but not a lot. If it is hard to turn then the fan clutch is locked up and needs to be replaced. It's about $100 bucks so I don't know how much your deductable is.
Old Jan 17, 2009 | 04:04 PM
BigRedMachine00's Avatar
BigRedMachine00
Is it air escaping or hissing, its hard to tell the difference. Possibly a cracked or loose vacuum hose?
Old Jan 17, 2009 | 05:33 PM
Durango03's Avatar
Durango03
It is a loud hissing noise. Its not any louder from one side or the other. I will have to try the (turning fan by hand) later, it was just driven. If it were a vaccum, wouldnt I be getting codes or atleast be running rough?
Old Jan 17, 2009 | 05:39 PM
Mean Green's Avatar
Mean Green
Depends on the size of the leak.
