nv242 planetary question
Old Jan 20, 2009 | 03:40 AM
bwboley's Avatar
bwboley
Default nv242 planetary question
i took my t case apart because was poping out the front end in 4w Lo well the planetary was all mest up the stud things were broke off and stuff.
my question is were can i get one or should i just get a new t case?
I found a nother t case for 100 bucks but its a NP 242d not sure if its the same?
Old Jan 20, 2009 | 02:56 PM
hydrashocker's Avatar
hydrashocker
I like this case personally and would stay with what you got. You don't know where the other case has been through?
Check here.
http://www.sixstates.com/products/products.jsp
Also maybe the dealer.
Old Jan 20, 2009 | 11:16 PM
master tech's Avatar
master tech
Site Moderator & Tech
The NP242 was in the 1998 thru 2000 Durango's, In 2001 started the NV244 T-Case. But to answer your question, The internal parts for the NP242 and NV244 are the same.
