Clikity Clank...No more 2 wheel drive?????
Old Jan 22, 2009 | 11:04 AM
Steve Ianni's Avatar
Steve Ianni
Unhappy Clikity Clank...No more 2 wheel drive?????
My family and I were on a trip up north when we were doing about 100kms and all of the sudden the truck started making a whirrrrrrrr and then a clikity clank, clikity clank. There was no drive left. The engine is fine and the RPM's behave normally....When I tried to put the truck in 4wdHi, it began to drive again...switch back to 2 wheel and clikity clank again and no drive. I'm able to drive around as long as i leave it in 4x4 but it is clanky and noisy at slow speeds and doesn't really seem to be in 4 wheel cuz i'm slipping in the snow easily...Someone please help....any suggestions?
Old Jan 22, 2009 | 05:25 PM
schusterjo's Avatar
schusterjo
Transfer case? rear axle? jack all 4 wheels up and see if all 4 wheels are turning to tell if you are in 4X4
Old Jan 23, 2009 | 04:53 PM
hydrashocker's Avatar
hydrashocker
In 4X4 you are using the front axel to pull you and the problem has to be in one of three places.
1. Transfer Case
2. Rear Axel
3. Drive Shaft
Old Jan 23, 2009 | 06:46 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
1. Transfer Case
2. Rear Axel
3. Drive Shaft
my thoughts exactly
Old Jan 23, 2009 | 08:34 PM
a4x44ted's Avatar
a4x44ted
Put it in 2wd. Put it in gear and have someone look under the D. Hold the break and give a little gas. If the driveshaft is turning but your not moving ( happened to me) It's rear gears or axleshaft. Mine was the gears. If the driveshaft doesnt turn, then transfer case. Just my 2 cents worth.
Good luck
Ted
Old Jan 24, 2009 | 06:18 PM
Mean Green's Avatar
Mean Green
Good luck
Ted
+2 on that
You will also be able to hear where your problem is.
Old Jan 25, 2009 | 10:35 PM
Silver01RT's Avatar
Silver01RT
I may have your solution but need to know if yours is AWD or not.
Old Jan 26, 2009 | 03:23 PM
Duranged408's Avatar
Duranged408
Originally Posted by shrpshtr325
my thoughts exactly
Wow you guys are really off.... Im ashamed you'd mention those things.. Like... Wow...
Im 100% sure its the left headlight bulb...
Old Jan 26, 2009 | 03:24 PM
Mean Green's Avatar
Mean Green
Damn I didn't even think of that! It may just need new fluid though.
Old Jan 26, 2009 | 03:50 PM
shrpshtr325
THE ULTI-MOD
damn your right, just make sure to replace the fuild w/ full synthetic
