so my 46re stoped workind so
Old Jan 24, 2009 | 08:18 PM
bwboley's Avatar
bwboley
Default so my 46re stoped workind so
i pulled the tranny apart and everything is new looking in as it was rebuilt in 07 but the front planetary gear is striped on the shaft but the shaft is good anyone know were to get one?
Old Jan 25, 2009 | 11:30 AM
Mean Green's Avatar
Mean Green
I'm sorry boley you lost me on this one. The sun gear's splines are stripped? Is that what you are referring to? You will have to order the whole planetary gear set for that section. I would check your local dealer, tranny shops, and do some searching around the net. If you want to check out www.thefastman.com and talk to Dan he might be able to help you out as he builds Dodge trannies as well as other go fast goodies.
Old Jan 25, 2009 | 09:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
Front planetary gear pn52118693 and 2892656 front planet annulus. Sun gear pn2801311. Rear planet 2801061 and rear annulus 4810002ab. and intermediate shaft if needed pn461711. All of these parts are dealer part numbers. Or if you can find a junk yard trans and get the internal parts out of it.
Old Jan 25, 2009 | 09:53 PM
hydrashocker's Avatar
hydrashocker
I beleive OEM or http://www.sixstates.com/products/products.jsp might have it.
Also you might be able to find one on the web or at your local trany shop.
Old Jan 25, 2009 | 10:00 PM
bwboley's Avatar
bwboley
Front planetary is what is bad the shaft is fine it chewed the spines on the planetary its self every thing in my tranny is still new looking damn and i bought a rebuild kit already..
Old Jan 25, 2009 | 10:07 PM
bwboley's Avatar
bwboley
http://800700tran.com/prod.itml/icOid/374
what one do i have? 3 - 4 or 5 pinion
