no tailights 2002 dingo
Old Jan 27, 2009 | 01:46 PM
tbasse01's Avatar
tbasse01
Default no tailights 2002 dingo
I have no tailights either side 2002 dingo
1. have swapped bulbs (no diff)
cant find a fuse related to the tailights can anyone help
Troy
Old Jan 27, 2009 | 11:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
Ck fuses 4 and 5 inthe PDC, thats under the hood. Black box. Use a test lite and ck all fuses. Just looking at the fuse doesn't work. You need to see if you have power. If the fuses are good,then remove one of the tail lite assy and unplug. ck the white/tan wire for power with a test lite. If you don't have power start tracing the wire.
