Rear door lock question
Old Feb 4, 2009 | 06:44 PM
en1gma01's Avatar
en1gma01
Default Rear door lock question
ok I have a problem with my durango locking. The doors lock and unlock fine but when I lock the doors it makes a wired noise. It's coming from the rear driver door because the door vibrates when the noise occurs. I took apart the door and everything seemed ok, but I really don't know what to look for. Thanks in advance
Old Feb 4, 2009 | 07:05 PM
hydrashocker's Avatar
hydrashocker
When you have the door panel off try it to see if anything is loose or if the motor might be loosing a bearing so it might be on the way out.
Old Feb 4, 2009 | 10:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
Its the door latch, makes a buzzing sound. Replace the latch and the noise will be gone.
Old Feb 5, 2009 | 12:57 AM
IndyDurango's Avatar
IndyDurango
Here is a how-to I put together on swapping out the rear door lock.
http://www.durangoclub.com/forum/viewtopic.php?p=102512
Good luck!
IndyDurango
Old Feb 5, 2009 | 11:46 PM
en1gma01's Avatar
en1gma01
Thanks for the info so I guess I need to buy new door latch. So when i go to dodgeparts.com is the part I'm looking for under body hardware? Thanks in advance.
