Passenger window goes down but won't go up
Old Mar 15, 2009 | 01:02 AM
tinmanchris's Avatar
tinmanchris
I just want to say a BIG THANK YOU TO ALL OF YOU! This method worked for me and I'm so happy to have my window working again! Just signed up for this forum to say this and I'm glad to be a part of this community!
Old Mar 15, 2009 | 01:16 AM
Kensai's Avatar
Kensai
You are very welcome Tinmanchris and welcome to the forums!
Just asking, what method did you use after reading this thread to resolve your issue?
Old Mar 15, 2009 | 10:53 PM
hydrashocker's Avatar
hydrashocker
Ya!
BTW<............ Welcome!
Old Mar 16, 2009 | 01:06 AM
tinmanchris
Reseeding the master switch worked like a charm. Took 2 minutes to get it working again.
Old Jun 22, 2009 | 01:43 PM
OUbeachbum's Avatar
OUbeachbum
Default Having same problem, but reseating driver side harness didn't fix-
My rear passenger window goes down, but not up. I can hear it make a clicking noise when I press the up button, but the window doesn't go up. It does this with all combinations of 2 different window regulator assemblies and 2 different rear power window switch assemblies.
I reseated the driver side switch harnesses (big and small) and the problem still exists.
Is the next step to replace the driver side master switch assy?
Thanks!
Old Jun 22, 2009 | 11:06 PM
hydrashocker
Sounds like a ground but a mutimeter would tell the tale.
Old Jun 23, 2009 | 05:29 PM
OUbeachbum's Avatar
OUbeachbum
The window goes down, but not up... this tells me the ground is OK I think.... unless a different ground is utilized during the UP state, but that doesn't make any sense...
Old Jun 23, 2009 | 07:13 PM
hydrashocker
Might be the switch on the drivers side that is the master.
Old Jun 24, 2009 | 01:46 PM
Kensai's Avatar
Kensai
You may need to use a multimeter to determine why it won't go back up. As you have already swapped the rear switches and motor assemblies, I would start at looking at the wiring harness connecting to the rear switch. This same wiring harness will also come from drivers door so if this harness has issues, it will affect both driver switch and rear door switch.
My guess is that it may be the wire harness plug itself that may be your trouble area and this area I would guess be at the rear door itself.
Check all wire harness plugs at the affected door to make sure a pin did not slide out of the plug or bent where it makes bad contacts, etc..
Old Jun 27, 2009 | 04:41 PM
Facory's Avatar
Facory
Often times the motor's amature develops a 'dead spot'. When it stops on that spot it will not work. Jarring it of flipping the switch may get some current into the armature enough to make it work. I've had that happen on both window wipers and the door motor. Had to replace both. If you are determined enough you can try to take the motor apart, blow it out, spray it with electrical contact cleaner and put it back together. The upside is that it could be a cheap fix. The downside is that you might have to replace the motor anyway. You might also try to spray some of the electrical contact cleaner into the switches.
