Caliper bolt keeps breaking
Old Mar 16, 2009 | 06:36 AM
ramgirl's Avatar
ramgirl
Default Caliper bolt keeps breaking
I have a 99 rango and she keeps breaking her caliper bolt. I buy the cheap $4 bolt and it will last about a week, go out and get the $40 oversize bolt and it will last 2 weeks. Has anyone had this problem and if so how did you fix it? I've already replaced the part that the caliper bolts up to 3 times. Any help would be great.
Thanx
Old Mar 16, 2009 | 08:22 AM
DRO318's Avatar
DRO318
Maybe the rotors are warped
Old Mar 16, 2009 | 12:06 PM
hydrashocker's Avatar
hydrashocker
Never seen this issue. I would bet you are using the wrong pads. The 02 and 03 pads were of different sizes if I remember right.
Thing is there isn't any torque on them as the pressure should go onto the control arm from the pads. Please send some pics and we will get her figured out for you.
I have some great ideas but you need to attach some pics. Get close shots of the caliper to control arm and the pad hangers. Anything else will help as well. Just get pic's from diffferent angles.
Old Mar 16, 2009 | 11:07 PM
IndyDurango's Avatar
IndyDurango
The only way a caliper bolt is getting broken is if the caliper is in a bind. Since you have been at it three times and its still broke, one can deduce that 4 out of 4 installs were done wrong.
Since this could kill you and someone else, just spend the $70 to have a brake shop pull off the calipers (give them some BS excuse) and ask for replacement bolts. If you have already went with the oversized, either those need to go back in or have them helicoil the bolts.
There is no load or significant torque on those bolts so something is way way wrong.
IndyDurango
DragonOfMadness's Avatar
DragonOfMadness
Different sized bolts?huh? Is there play in the caliper when you bolt it back on?----compress the caliper all the way in with the bleeder open or the cover off the master cylinder and compress the caliper all the way in and mount it=if theres any play side to side etc..replace the caliper and the mounting bolts-- do both side= for safety sake....Have the hub bearings checked for play but the truck wandering and making noises with a bad hub bearing...hope this helps...
Old Mar 16, 2009 | 11:08 PM
DragonOfMadness
Damn you INDY you posted before me=lol@!
Old Mar 17, 2009 | 02:16 PM
hydrashocker
There is a DIY write up in the main thread section "D' 1st gen that has a write up on "helicoil" fix.
Here:
Front Brake Thread Repair.
https://dodgeforum.com/m_1230920/tm.htm
Old Mar 17, 2009 | 04:47 PM
ramgirl's Avatar
ramgirl
thanx everyone. i'm going to pick up another spindle then going to helicor it.
Old Mar 12, 2011 | 08:08 PM
Durango-frustration's Avatar
Durango-frustration
Hello-
Been reading some posts here- and wondering if somebody could assist please.
My caliper bolts apparently became loose -never even heard of such a thing happening until yesterday! Anyways- that part that the caliper bolts in to is now broke and needs to be replaced.
Could somebody inform me what the name of this part is please.
Thank-you
Durango-Frustration
Old Mar 12, 2011 | 10:35 PM
MAGIC84's Avatar
MAGIC84
This is a SERIOUS SAFETY ISSUE I would recommend having it inspected professionally spend a few bucks and it will save you later.
