tranny fluid
Old Apr 2, 2009 | 09:48 PM
bentley09's Avatar
bentley09
Default tranny fluid
i put in atf in my 98 dodge durango then to realize that you needed a certain type of tranny fluid. i put in dexron-III and mercon in it what will happen and is there a way i can fix it.
Old Apr 3, 2009 | 12:45 AM
DragonOfMadness's Avatar
DragonOfMadness
You could drop the pan and change it to atf+4...Is it shifting weird?
Old Apr 3, 2009 | 02:42 AM
schusterjo's Avatar
schusterjo
Well it is not going to be an instant killer but you will want to change it out soon as possible. What you have put in your transmission is a fluid that has a lesser of lubricating properties. Your transmission requires the best and that is ATF+4 (it is synthetic). So, you can see where by adding fluid that should not go in can cause an issue.
Old Apr 3, 2009 | 12:17 PM
min624's Avatar
min624
Default fluid + lubricant
last month i put new ATF+4 fluid plus a quart of Lucas tranny lubricant into my 2002 R/T. does anyone think this was a bad idea or would it actually help?
Old Apr 3, 2009 | 01:09 PM
schusterjo's Avatar
schusterjo
Well I know manufacture says no additives.. I like Lucas, never used it on my tranny but used it for other things. I personally don't see where it will hurt but some here might say you should not do it.
Old Apr 3, 2009 | 05:20 PM
hydrashocker's Avatar
hydrashocker
Do a change.
The OEM is ATF+III but the Fully Synthetic version that replaced it is ATF+4.
You will need to drain, fill and run 100 miles and drain filter and fill.
Since you will be filling it up you might what to install this into the OEM pan to make it drain like a oil pan.
Old Apr 3, 2009 | 11:52 PM
DragonOfMadness
I love lucas tranny additive, but you MUST do the tranny adjustment to the bands..lucas will help but please adjust the bands I did mine after the lucas add and my tranny is like new=my truck has over 190500 now but I don't know if the tranny has been rebuilt or replaced etc..Lucas is good but do the band adjustment...
Old Apr 4, 2009 | 12:40 AM
schusterjo's Avatar
schusterjo
I need to put one of those on my pan.. been meaning to but just have not done so yet.
Old Apr 4, 2009 | 05:03 PM
hydrashocker
There so nice!
Better if you can tack weld the nut while it's out.
I don't like Lucus or any other additive period!
