Milky color oil under fill cap?
Old Mar 6, 2005 | 05:38 PM
natedogg's Avatar
natedogg
Default Milky color oil under fill cap?
I have a 00 Durngo with a 4.7L. I change my own oil. When I was draining it, I did not notice anything wrong. When I went to fill it, there was a white milky substance under the cap. I thing that gets me is that it doesn't show on the stick. The dealership said that it was just condensation. Has anyone else come across this? I am a little worried that it might be a head gasket or something. Any info would be great.
Old Mar 6, 2005 | 07:06 PM
ramfan5.9's Avatar
ramfan5.9
Default RE: Milky color oil under fill cap?
water will make oil whitish
they are probally right juss condisation
Old Apr 30, 2005 | 02:34 AM
crankin1's Avatar
crankin1
I had the same problem with my 01 4.7, the dealer said these motors are very hard on oil and to follow the recomended change intervals. Everything was like they said until my wife went 1500km over on 2 oil changes in a row and it came back a little bit. Mabye the dealer actually told the truth.
Old May 6, 2005 | 04:01 PM
Kensai's Avatar
Kensai
Problaby would have you intake manifold gasket checked. Read either on this forum or from another forum a long time ago that Chrysler had a TSB on this. Antifreeze can slowly leak into the oil and eventually seizing up your engine! And the leak is mostly internal so you will not be able to visibly see anything outside the engine. I think another user in this forum posted something about this also.
So it would not matter even if you change your oil every 3k using synthetic, if it continues to have some abnormal coloration to your oil when you change your oil, better get that gasket checked or you will soon be out without an engine.
Old May 7, 2005 | 12:17 AM
Vader's Avatar
Vader
I was told it could be from starting and running in few minute intervals. Quick heating and cooling may induce condensation.
Old May 7, 2005 | 12:35 AM
moparturd's Avatar
moparturd
The vapor get trapped in that area of the engine. Then condense on the cap.
Old Jun 16, 2005 | 03:15 PM
saydee's Avatar
saydee
This a known problem, there is a TSB for it. You need a different oil filler cap, dealer has them for around $10. The problem is that water vapors mix with the oil and you get a milky foamy emulsion.
Hope that helps!
Old Jun 17, 2005 | 03:51 AM
uawnick's Avatar
uawnick
worst case scenario you have a blown head gasket though.... coolant could be mixing with the oil... I hope that isnt it, I hope its the vapor thing, head gaskets are a pain
good luck
Old Jun 17, 2005 | 05:08 AM
Saint's Avatar
Saint
It's what saydee said, it's emulsification of the oil. It has to do with the oil filler being on the front of the engine, during cold weather the filler is exposed to cold air and that causes condensation on the inside of the filler neck. Nothing to worry about, but get that other filler cap.
Old Jun 25, 2005 | 02:50 AM
cooleod's Avatar
cooleod
Don't sweat the milky color oil. I get it sometimes on my motorcycle when I ride on short trips. It is most likely just condensation in the motor and when you don't run it long enough, the condensation doesn't have time to evaporate giving you the milky residue.
