Output Shaft Speed Sensor Question..
Old Apr 9, 2009 | 12:35 AM
stokes84's Avatar
stokes84
Question Output Shaft Speed Sensor Question..
So my 2000 Dodge Durango is shifting hard and can't get above 3rd I believe. I took it into the dealership and they noted a bad cv boot and replaced it and told me it was a "bad output sensor". I said I'll handle that one and assumed output shaft speed sensor. They didn't give me the code or any other info(ya, real nice huh?). So I ordered this sensor from Baxters (part # sc226). I located the sensor that matched (passenger side of the transmission I believe). Got it out and saw they didn't match, one is a 2 pin connector and the existing sensor is a 3 pin. Just making sure I in fact got the wrong part and didn't pull the wrong sensor. Thanks
PS the retaining screw hole broke up while I was struggling to get it out.
Old Apr 9, 2009 | 09:50 AM
Neo1130's Avatar
Neo1130
I think the top you one got is for ABS? What it looks like to me!
Old Apr 9, 2009 | 09:53 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would have thought the one on the tranny output shaft too, but when i had to mine on my old truck(98 dak) it didnt look like either of those so i would say that yes, you got the wrong sensor from the store
Old Apr 9, 2009 | 09:55 PM
stokes84's Avatar
stokes84
bump, anyone know the part number I need by chance?
Old Apr 10, 2009 | 06:26 PM
hydrashocker's Avatar
hydrashocker
The new one looks like a speed sensor.
You want a Transmission Output Sensor and it is on the driver side.
Old Apr 10, 2009 | 11:58 PM
schusterjo's Avatar
schusterjo
ya that does look like the speed sensor (new one)
Old Apr 11, 2009 | 12:19 AM
dhvaughan's Avatar
dhvaughan
i'm not an expert on durango's, but on the ram, there is a round vehicle speed sensor (VSS) on the output shaft of the transmission, and an ABS sensor in the top of the rear differential that looks similar to your new one in the first pic. try rockauto.com and here for an application guide w/pics.
http://www.standardbrand.com/web_app...liccatalog.asp
just by the way... you took your car to the dealer because it was shifting hard and they replaced what was probably an expensive CV boot but not a $25 sensor. wtf did that have to do with shifting. find another mechanic...
Old Apr 11, 2009 | 12:31 AM
schusterjo's Avatar
schusterjo
Sorry I did not read the full post the first time.... Yes if it is on the rear of the transmission(output shaft) then it is the speed sensor... They did change them but do not remember the exact year... Mine has this one here
http://www.autozone.com/autozone/cat...equestid=88086
So just take it to autozone and have them match it up
Old Apr 11, 2009 | 11:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
In reading the post, I know the durango is a 2000. But I don't the engine size, that way I can help you out on your sensor problem. Engine size tells me if you have a 46RE trans or 545RFE trans.
Old Apr 12, 2009 | 12:16 AM
hydrashocker
I sware they also put a 42RE in there as well.
