p1765 and p0753
Old Apr 15, 2009 | 10:33 PM
moparornocar91's Avatar
moparornocar91
Default p1765 and p0753
Alright, So i own a 99 dodge durango 5.9slt. It has about 144k miles on it with a rebuilt tranny only about 5k old. I keep getting engine codes p0753 and p1765. My scanner says its a solenoid a electrical problem, and a 12v relay controll or something. Is there any easy fix, such as a fuse or relay under the hood? Or am i going to have to take apart my tranny to get to a solenoid? Any advice would be great
Old Apr 20, 2009 | 10:38 PM
hydrashocker's Avatar
hydrashocker
P0753 Trans 3-4 Shift Sol/Trans Relay Circs
P1765 Trans 12 Volt Supply Relay CTRL Circ
Sounds like the harness to the trans isn't getting connection so double check the harness connection........OR....... There are metal fragments inside the pan hanging the solenoids up. In this senerio the shop did not do a good enough job cleaning out the system or there is a wire arching.
Personal Message master if needed. master tech
