engine failure questions
Old May 13, 2009 | 05:14 PM
  #21
hydrashocker's Avatar
hydrashocker
You can find many answers in here: Do It Yourself (top questions and answers)
Towing and Gearing Ratio's. (some info is off a small bit)
https://dodgeforum.com/forum/1st-gen-...-question.html
http://www.allpar.com/model/durango-...fications.html
http://www.allpar.com/model/durango.html
Old May 14, 2009 | 07:41 AM
  #22
Duranged408's Avatar
Duranged408
I will now attempt to describe "Engine Failure" on behalf of INDY DURANGO in the least amount of words.
Old May 14, 2009 | 05:45 PM
  #23
hydrashocker
^ lol ^
Old May 14, 2009 | 10:47 PM
  #24
MAGIC84's Avatar
MAGIC84
That looks remarkably like a 4.7 LOL!!
Old May 14, 2009 | 11:31 PM
  #25
IndyDurango's Avatar
IndyDurango
No comment. (lol)
IndyD
Okay I'll comment... gotta love that plastic intake manifold!
Old May 16, 2009 | 02:17 PM
  #26
hydrashocker
And we wonder why I don't like em.
Old May 16, 2009 | 08:52 PM
  #27
MetalDrgn's Avatar
MetalDrgn
Well I finally got it back. Wow was that a pain. It was a ride filled with much peril and adventure. Rented a car dolly to pull my s-10 . So many things could have gone wrong… I don’t ever want to do that again without more planning.
Old May 17, 2009 | 01:12 PM
  #28
hydrashocker
Why?????
Old May 17, 2009 | 04:56 PM
  #29
MetalDrgn's Avatar
MetalDrgn
because of atlanta traffic/construction and the fact that I had to drive 300+ miles each way to get it. it was hard to keep the durango from swerving because the one I towed with has a little play in the steering and is the same weight and the lanes were narrow. I was also very tired. it was a rough ride.
btw it looks like the knocking is from a loose connecting rod possibly... it is burning oil too which is weird (i hope it didn't punch through a piston or bent a valve or something, but I'm guessing it probably did), but I've removed spark and fuel from each cylinder and it's still knocking. I also have my fears because the #8 plug had oil on it and it had a bent tip. I'm going to have to pull it and see if it bent the new plug too. the durango has 135000 miles on it and never had the spark plugs changed from what I can tell so I replaced them all. they looked like they were twice the gap as normal. I will post pictures if you want. my oil fill port was also slimed up like in the pictures and I can post some pictures of that too.
Old May 19, 2009 | 06:24 PM
  #30
hydrashocker
Sounds like a bad valve guide.
