cruise control does not work
Old May 17, 2009 | 02:24 PM
sweden75's Avatar
sweden75
Default cruise control does not work
Hi
I have a durango 2001 2wd 4,7 liters
My cruise control does not work i can se the ligth go on when i turn ignition on and hold breakpedal down and press cruise switch on,and when a take a drive to test the cruise control it only ligts for just a second and then to disaper.i have a errorcode thats says P1595 (speed control solenoid circuits.) I have read some treads here about brake ligts alwas ligths i have not that problem could it be that anyway or maby it is something else that i can check to get this fixed and where does the brake ligth switch mounted so a can replace it in case it is that problem i have?
best regards from sweden
Old May 19, 2009 | 06:28 PM
hydrashocker's Avatar
hydrashocker
Light switch is located under the dash mid way up the brake pedel on a braket and has a 1/4 turn to pull it off. Look at the new one.
Old May 19, 2009 | 08:26 PM
schusterjo's Avatar
schusterjo
They are pretty cheap as well... let us know if that ends up being your issue.
Also check out this link
https://dodgeforum.com/forum/1st-gen...t-working.html
