Map Sensor and PCV Valve location
Old Jan 21, 2018 | 03:52 PM
  #31
kycruiser1's Avatar
kycruiser1
I have a 2000 Dodge Ram with the 5.9L and there is a PCV valve on the drivers side of the engine and a ventilation elbow that looks just like a PCV valve on the passenger side of the engine with a hose that runs to the breather hat. Be careful not to confuse these.
Old Jun 2, 2018 | 08:56 PM
  #32
Coco Alberto's Avatar
Coco Alberto
Question Pcv valve located
Where can i locate my pcv valve in my 2004 viper srt10 ram ? I need to change it !! any pictures need help
Old Apr 21, 2019 | 04:26 PM
  #33
Christie Woods's Avatar
Christie Woods
Originally Posted by Kensai
Okay, I am totally lost here! I just got off the phone arguing with the Dodge parts guy about the pcv valve location on the 2000 5.9 motor. I found out the hose that connects the pcv valve to the intake manifold is strictly dealer item only as napa/autozone does not carry this hose. He says the pcv valve is on passenger side, but I say it is on drivers side. As you can see in my pic and part replacement. he claims the driver side is just a breather element????? Heck, I went back to my truck and pulled the passenger side which initially I thought was pcv valve but looks like a straight thru plastic elbow(it does resemble a pcv valve). I will be heading to Dodge parts counter tommorrow morning to pick up both PCV hoses for passenger and driver side and told the parts guy to get me the supposively pcv valve for passenger side.
Now I wonder, as I am the second owner of this truck, I wonder if some idiot that worked on this truck may have reversed the pcv valve and the breather valve???? My lunch break is about to start so I will head down to the parking garage and pop open the hood and look one more time.
I will call back and talk to the service guy instead to get a more accurate answer on pcv valve location.
So just curious, for you 5.9 owners, where is your PCV valve located?
Mine is on driver side. Directly to valve cover
Old Oct 27, 2021 | 12:02 PM
  #34
Trevor Shiffermiller's Avatar
I have a 1996 360/5.9 Magnum. Love my truck and had it since new. Thank You for the original write up. I am replacing my MAP sensor this weekend along with Oxygen Sensors and PCV valve all as preventative maintenance in hopes that fuel mileage will go back to closer to when it was new.
I am writing this to just say thank You to the original poster from 2009 and so he knows we are still using his information in 2021!
