Wiring colors
Old Jun 2, 2009 | 11:19 PM
Dans01Durango's Avatar
Dans01Durango
Default Wiring colors
Hi guys. I was wiring a a pusher fan in front of the a/c condenser and I installed a fan control with a thermal switch. What I want to know is what wire could I draw power from from the power distributoin box that won't blow a fuse. The fan is an electric fan made by torqflo it draws about 11 amps.
Old Jun 3, 2009 | 02:09 AM
IndyDurango's Avatar
IndyDurango
From the power distribution center under the hood, grab 'key on power' from the Fuel Pump relay.
HTH.
IndyDurango
Old Jun 3, 2009 | 09:16 AM
Dans01Durango
Thanks Indy! But stupid question, what color scheme is that?
Old Jun 3, 2009 | 11:07 AM
Neo1130's Avatar
Neo1130
Don't go by color... They vary from year to year and engine to engine...
Old Jun 3, 2009 | 12:03 PM
Dans01Durango
Thanks Neo, so which prong is the "key on power" for the fuel pump relay?
Old Jun 3, 2009 | 04:17 PM
lv360ram's Avatar
lv360ram
I was also thinking about a pusher fan in front of the a/c condenser but it looked like the grill is too close. What diameter is the fan and what is the thickness?
Old Jun 3, 2009 | 09:40 PM
Dans01Durango
Hi lv the dia. is 14 inches and the thickness is 3 5/8 inches. I had to do some modding to the grill and plastic bumper piece but I got it to fit right against the driver side of the condenser. I used 2 of the push through zip ties to help hold it in place. I hooked it up to a themal switch and the thermal switch to the battery. That's why I want to find out which wire I can use to only give it power when the ignition is on. I set the thermal switch too low and almost ran my battery down! I caught it in time but I had to set the temp. kinda high before the switch kicked in. I don't want to burn my motor so I want to keep the temp low around 195 or 200.
Old Jun 3, 2009 | 11:22 PM
IndyDurango
IIRC, 87. The EEs can chime in now!
IndyD
Old Jun 4, 2009 | 12:00 AM
hydrashocker's Avatar
hydrashocker
If it's on a fuse then hard wire to the PDC input from the battery.
Old Jun 4, 2009 | 07:10 AM
Dans01Durango
Hydra, thanks for the tip. I have it hooked up to the battery directly, isn't that the same as hard wiring it to the battery input to the PDC? I have an inline 30amp fuse connected to the switch and I just want to find out which terminal or fuse I can use in the PDC so the fan will only be powered when the engine is on. I don't need it to be "hot" all the time.
