a/c trouble
Old Jun 8, 2009 | 06:07 PM
shaner's Avatar
shaner
Default a/c trouble
I noticed my air conditioning was not very cold on my 01 durango,so I decided to add freon.As I was adding freon I noticed my compressor would kick on for 1 second and then shut off for 10 seconds,even though I had both front doors open so it would be hot inside and a.c. would not shut off.On occasion it would make this noise and release {I am assuming freon} out of the back of compressor.Any ideas what is happening and what i need to do to fix it....thank you in advance
Old Jun 8, 2009 | 08:31 PM
Neo1130's Avatar
Neo1130
Either your low or high pressure switch is being engaged... What is the pressure on the line? Please tell me you are using a kit with at least a gauge?
Old Jun 9, 2009 | 12:47 AM
IndyDurango's Avatar
IndyDurango
You are very low on freon. Some can do the recharge at home with the right tools. Unfortunately a can and the hose you get with it isn't the right tools. Spend $99 and get it recharged at a shop somewhere. If you don't it could get worse/cause problems.
Speaking of which, you could already have problems. Where did the freon go that was in there? Name:  icon_confused.gif
IndyD
