2002 Durango RT 5.9
Old Jul 7, 2009 | 09:33 PM
squashu's Avatar
squashu
Default 2002 Durango RT 5.9
Hi...
My Durango has a weird shift issue. It will hold to either 2800 RPM or 3500 RPM before up shifting. Only seems to do it if I've been driving for a while on the highway then stop for a set of lights and then continue or if I'm driving pretty aggressively.
Weird part is if I stop and put it in park then back in Drive it goes away.
Already replaced the
governor pressure sensor and governor pressure solenoid in the transmission as that was recommended in a reply from a previous post.
Any suggestions?
Is there such a thing as a reboot for the transmission control computer or a software reload? Someone suggested that it may be a software issue.
Thanks!
Old Jul 8, 2009 | 07:53 AM
Duranged408's Avatar
Duranged408
If you have the same transmission (i cant think right now) you could also need the to have the bands adjusted in your trans (suggested a dealer service).. Im kinda busy right now but if i get some time i'll try to give ya more info
Old Jul 8, 2009 | 09:00 AM
squashu's Avatar
squashu
Thanks,
I have the 46RE transmission.....I think this is the same for all 5.9s 1998-2003
If you have some more details that would be great.
sean
Old Jul 8, 2009 | 05:44 PM
hydrashocker's Avatar
hydrashocker
Could be a pressure issue or adjustment issue.
Old Jul 9, 2009 | 12:45 AM
IndyDurango's Avatar
IndyDurango
Does the speedo dance around when it is holding the high RPMs without shifting? If so, I would diagnosis it as the pressure governor solenoid.
IndyDurango
Old Jul 9, 2009 | 09:24 AM
squashu's Avatar
squashu
No its very steady to either exactly 2800 or 3500 RPM. We did the gov pressure solenoid a few weeks ago to try and fix the problem. Seemed better for a while but issues still there.
Old Jul 9, 2009 | 07:31 PM
hydrashocker
Have you manually turned the pressure down?
Old Jul 10, 2009 | 08:39 AM
squashu's Avatar
squashu
thanks,
How do you do that?
Old Jul 10, 2009 | 01:55 PM
hydrashocker
Heres all the info that you'll ever need.
https://dodgeforum.com/forum/1st-gen...d-for-now.html
