brakes?
Old Jul 21, 2009 | 04:14 PM
mrwilliwizard's Avatar
mrwilliwizard
Default brakes?
is it just me or do the brakes that come on the durango blow! any good after market brake system upgrades for this car?
Old Jul 21, 2009 | 10:11 PM
hydrashocker's Avatar
hydrashocker
The Durango brakes are too small.....IMHO
I like running good rotors of your choice (slotted or not) and DuraLast Gold Series Pads from AZ. Ceramic are good but not meant for hilly terrain and towing.... both provide little dusting......Each to their own.
Old Jul 21, 2009 | 11:31 PM
IndyDurango's Avatar
IndyDurango
Good pads and good rotors are your best friend. Yes the Ds brakes are undersized. Only the 2003 got it close to right on the Gen1s.
IndyD
Old Jul 22, 2009 | 12:18 AM
mrwilliwizard
awee bummer lol. i really dislike the drum brakes as well. how do you know when the drum brakes should be replaced? cause i have no clue ha. but i'll look into different rotors and pads thanks.
Old Jul 22, 2009 | 12:35 AM
mrwilliwizard
o one quicky. when should you change your brake fluid? or get it repressurised and what not. to make the pedal more firm
Old Jul 22, 2009 | 01:45 PM
hydrashocker
+1 Indy!
Take off a wheel and drum and look at em. Also there is a window on the back side of the dust shield on the axle side on the bottom.
You just change out your brake fluid. You do not re-pressurize the system, it has it's own and it uses the peddel....... Pull the fluid out of the master cylinder and pour new in. Then use a vacuum bleeder at the wheel or a pressurize the master using a bleed gun. This is the best way but each to their own. Most people take it in and have it done for like $60.
Fluid will turn dark in color when dirty or oxidized. Usual interval is about 60k.
Old Jul 23, 2009 | 09:54 AM
Dans01Durango's Avatar
Dans01Durango
Just redid mine. The pedal feels much better. Before it was like almost to the floor but now it works like it should be. I didn't need to change the pads or rotors but I felt it was something that needed to be done. I took off all the parts and saw that the pad backs were scaled with rust and a few places there was chipping of the pads so that was a good call. The rotors were not smooth like they should be but kinda smooth/bumpy. There was also a raised line on the right rotor cause by uneven wear of the outside right pad. Anyway, it was a good preventive measure.
Old Jul 24, 2009 | 01:03 AM
hydrashocker
What pads and soes did you go with?
Old Jul 24, 2009 | 02:13 PM
Dans01Durango
Duralast gold shoes and valucraft rotors, hydra. Both from AZ.
Old Jul 24, 2009 | 04:39 PM
IndyDurango
DL Golds are good for general pads.
The rotors however... I would expect warpage there. Keep us posted.
IndyD
