hey i need help with the right side front window
Old Jul 22, 2009 | 10:01 PM
dodger2638's Avatar
dodger2638
Thumbs down hey i need help with the right side front window
hey thanks for stopping by!! i have a problem with my pasanger side power window it wont roll up from that side or the driver side, but the master switch does work for the back windows!! and i put a new window motor already and regulator? im just kinda stuck on what the problem could be. if anyone might know could you give me some advice? thanks josh.
Old Jul 23, 2009 | 01:07 AM
mrwilliwizard's Avatar
mrwilliwizard
hmmm that happened to me. the durango windows are kinda crappy. i think your motors fine but the wire from your motor which connects to the window mount might have came loose, it happened to me twice the little plastic "clip" if you will that holds the wire and gives it tension could of broken off. i had to take off the inside panel and tie the wire back onto the mount . take the paneling off and see whats up.
Old Jul 23, 2009 | 09:58 AM
Dans01Durango's Avatar
Dans01Durango
You may also want to check the master window switch on your driver door. Sometimes the master switch just needs to be changed out or the connections cleaned and grease with dielectric greas to fix the window problem.
Old Jul 24, 2009 | 12:39 AM
hydrashocker's Avatar
hydrashocker
The master switch has diodes inside that can short out the connection. Check the wiring then move to the drivers side switch.
See this thread!
https://dodgeforum.com/forum/1st-gen...w-problem.html
Old Jul 24, 2009 | 12:41 PM
dodger2638's Avatar
dodger2638
hey guys thanks for all the help!! now i just remembered i had put a system in my car and it vibrates quite a bit so wat do u guys think? thanks alot
Old Jul 25, 2009 | 01:39 PM
hydrashocker
You might need to install anchors. I assume the car is your Durango?
