tow worthy
Old Aug 8, 2009 | 11:44 PM
Jasperstang308's Avatar
Jasperstang308
Default tow worthy
ok i have an 01 durango. what all do i need to make it tow worthy?
i was thinking better brakes, (you need to stop with what your towing) any recommendations?
tow hitch
trans cooler
what do i need?
Old Aug 9, 2009 | 09:54 AM
gr8scott72's Avatar
gr8scott72
tow hitch
trans cooler
what do i need?
What engine do you have?
What gears do you have?
How much do you plan on towing?
How much do you want to spend?
Old Aug 9, 2009 | 01:14 PM
Jasperstang308
4.7
i'll let you know when i check the sticker in the glove box that you mentioned,
a trailer with a 87 mustang on it. it should weigh somewhere around 2700lbs
i guess that depends on what i need
Old Aug 9, 2009 | 02:14 PM
schusterjo's Avatar
schusterjo
Defiantly a trans cooler, maybe a radiator flush if you have not done so in awhile. others will chime in with more info.
Old Aug 9, 2009 | 02:21 PM
Jasperstang308
i did a radiator flush last year so that part is taken care of. any recommendations on the trans cooler?
Old Aug 9, 2009 | 02:50 PM
schusterjo's Avatar
schusterjo
B&M Automatic Transmission coolers are very good quality coolers. They make several types, just look at "tow capacity recomendations) and find one you like.
I should add they sell some that come as a direct fit to the Durango including lines and all to use.
Old Aug 9, 2009 | 07:32 PM
hydrashocker's Avatar
hydrashocker
4.7
First off that would not be the correct weight because you have to add the car weight and the trailer weight. Open trailer weight of a 16' trailer is at an average of 1,600 lbs then add the weight of the car at an average of about 3,200 lbs you get 4,800 lbs which is over your max if you have 3:55 gearing but if you have 3:92 then your ok. IF you tow this you need to make sure your weight is with in the law in case you get into a wreck.
I would install a Transgo Shift Kit, and this is one of the transmission coolers I hve installed:
http://www.bmracing.com/PRODUCTS/Aut...U-11x7-1-2x3-4
Here is some more info:
Gearing Ratio's and Towing
https://dodgeforum.com/forum/1st-gen-...hat-gears.html
https://dodgeforum.com/forum/1st-gen-...-question.html
http://www.allpar.com/model/durango-...fications.html
http://www.allpar.com/model/durango.html
Old Aug 9, 2009 | 07:47 PM
Jasperstang308
i meant the car should weigh around 2700lbs
Old Aug 9, 2009 | 07:51 PM
Jasperstang308
also according to what hydrashocker said my D has 3.55 gears
Old Aug 9, 2009 | 07:53 PM
Jasperstang308
also how will the shift kit help with towing? does it help hold the gears out or something? my local track is about 20 min away but i want a reliable 20 min too and from through out the summers
