2000 Durango Rough Start-up
Old Sep 20, 2009 | 11:25 PM
hydrashocker's Avatar
hydrashocker
Champion Copper plugs (OEM) yes these are the $2 plugs or Champion Truck plugs $3, or Champion Iridium plugs $9.
I would only use one of these.
Old Sep 21, 2009 | 01:45 PM
thunder26's Avatar
thunder26
just the plugs or get the wires too?
Old Sep 21, 2009 | 07:14 PM
lv360ram's Avatar
lv360ram
Originally Posted by thunder26
My 2000 durango has a tough time starting. I turn the key forward and it takes an extra 3 seconds or so before the engine fires. Once the engine fires it runs a little rough until I rev it up to 2000 rpm or so and/or start driving it down the road. I have been told maybe fuel pump or oxygen sensor, any ideas??
Usually the fuel pump will pressurize the line quickly so the engine will start quickly. However, if you are cranking an extra 3 seconds then the fuel pump may be going bad. Same thing happened to me. Replaced fuel pump and starts instantly.
Clues:
Takes longer to start first time in morning after sitting overnight.
Starts quickly after being off for only a few minutes.
Test:
Before turning the key to start - turn key to on, wait 3 seconds, turn key off then turn key to start. Does it start quicker?
Maybe someone will prove me wrong.
cap, plugs, and wires are easier to replace than fuel pump.
Old Sep 22, 2009 | 04:40 AM
thunder26's Avatar
thunder26
Thanks everyone for the help, i think i'm going to replace the plugs, wires, and cap just to tune it up a little bit and if that doesn't fix the problem i'll go for the fuel pump.
in response to the last post - yes the initial start of the morning is tough and it seems if i drive it a little while and turn it off and back on it starts right up so you may be onto somethin there...
Old Sep 22, 2009 | 01:49 PM
IndyDurango's Avatar
IndyDurango
FYI... You don't have a cap, you have a 4.7 remember?
IndyD
Old Sep 22, 2009 | 10:32 PM
hydrashocker
You have a 4.7L so you don't have wire, cap, or rotor. You simply have coil over packs (one on each plug). You simply take the coil over off and remove the plug. Gap the plug and reinstall for each one.
This is the good reason for ownership of the 4.7L over the 5.2L or 5.9L.
Old Sep 23, 2009 | 12:49 AM
IndyDurango
If you call all that extra crap that can fail "good" and the fact one coil pack costs more than our wires, cap and rotor to replace if need be, and there there are 8 of those packs or more depending on the year of the D... yea... that's the good reason for 4.7 ownership.
J/k! Good luck on yours. Again, swap those plugs and let see what happens!!
IndyD
