4 Wheel Drive Linkage Grommets - How to install??
It's a 2000 Durango 4x4... I was pulling an old boat out of a wooded area and decided to use the 4 wheel low when the shifter gave and then nothing. You could move it front to back with no effort at all. The standard Drive then wouldn't egage because the 4 wheel drive shifter was in the neutral state when it broke. I figured this out after I drug it home and got it in the air. Apparently Dodge installs the linkage between the 4 wheel drive and the transmission with the use of grommets that a linkage piece snaps into. These grommets rot in time and that allows the linkage to just.. .fall out. Thank goodness it got hung on the rock guard. So bought new grommets... and went to install them. And I'll be damned if I can't get them in! Any suggestions on how to get them into the holes? They just don't want to go...
No rattle... what made me use the c-clip is i actually broke the new grommet trying to get it in. So, i said forget about it and used the c-clip, works and did not rattle. just an option if ya not able to get it in.
