Electric Fan Not Working?
Old Oct 9, 2009 | 03:58 PM
hydrashocker's Avatar
hydrashocker
I hear Indy has a good one!
Old Oct 12, 2009 | 08:08 PM
marksoup's Avatar
marksoup
thanks for the responses!
I did switch out the relay and it was not the culprit. I assume it is a dead elecdtric fan. I went to the dealer for the part and they wanted $337. I chatted it up with the girl behind the parts counter adn was able to get her down to $240 for the OEM part vs. going out and trying to find an aftermarket version.
On a seperate note: I did start hearing a loud ROARING noise from the engine area the other area. Sounds as if the engine is working too hard to get going. Not sure what the heck that is... I had the tranny replaced approx 1 year ago and the D is switching gears OK. It seems to stop ROARING after I reach approx 25 - 30 mph.
Ideas on that one?
Regards,
Mark
Old Oct 12, 2009 | 08:40 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if the roaring is from a cold start after sitting all night its just the clutch fan catching . . . (this could also be the case if the truck is running too hot) and its something to worry about as long as it goeas away w/in the first mile of driving every morn
Old Apr 11, 2010 | 10:25 PM
firstyearta's Avatar
firstyearta
I am having this same issue with my 2000 Durango (Elect. fan not coming on). I tried swaping out the fan relay for one of the other relays and the fan still did not come on. I unhooked the power wires and wired 12V directly to the fan and it came right on. I am right that no matter what the condition is, if the A/C is on, the electric fan should come on too, right?
So what else would cause the electric fan to not come on.
BTW, I noticed the electric fan does not come on with the A/C in my 2001 Dakota either.
Thanks in advance for any help.
Old Apr 11, 2010 | 10:44 PM
firstyearta
However... now after hooking up direct 12 volt and then plugging the harness back together, it seems to be working just fine... though I don't know why it is now and wasn't before.
Old Apr 12, 2010 | 12:40 PM
shrpshtr325
THE ULTI-MOD
probably a loose connection and unplugging it and plugging it back in was enough to tighten it up
Old Dec 8, 2011 | 06:02 PM
CJ7 Troy's Avatar
CJ7 Troy
Where is the plug for the fan located on a 2003 Durango ? I am having the same problem.
Old Dec 8, 2011 | 06:29 PM
shrpshtr325
THE ULTI-MOD
its near the bottom of the radiator, above the plastic splash guard
Old Dec 8, 2011 | 06:50 PM
CJ7 Troy's Avatar
CJ7 Troy
Thank you I will check that tomorrow.
Old Dec 8, 2011 | 07:56 PM
shrpshtr325
THE ULTI-MOD
if you follow the wires coming out of the center of the fan (they are tied along one of the electric motor braces) you really cannot miss it.
