4.7L Durango issue HELP!!!
Old Oct 13, 2009 | 03:46 PM
teamdynasty1's Avatar
teamdynasty1
Default 4.7L Durango issue HELP!!!
Hello got a 2000 durango with a 4.7 in it i threw a check engine light 2 weeks ago saying system too lean , and bank 1 o2 signal delay.. the truck was throwin out tons of smoke under a heavy load and smelt like gas all the time i was getting about 3mpgs everywhere so i assumed that it was a o2 failure and changed the upstream sensor and everything went back to normal.. then about 3 days ago the light came on and i was getting the same codes and symptoms and instead of blowing anothr $80 i figured id look fo some help so if anyone know please help
Old Oct 13, 2009 | 09:49 PM
rebelboy's Avatar
rebelboy
sounds like a faulty sensor bring it back to the store and bugggg out
Old Oct 13, 2009 | 09:51 PM
rebelboy's Avatar
rebelboy
then run sea foam to clean that monster
Old Oct 13, 2009 | 10:02 PM
teamdynasty1
kinda thought thats what it was since i got it from napa ive never bought a part there that didnt fail in the first week unless it was oil or plugs ha
Old Oct 13, 2009 | 10:04 PM
teamdynasty1
can you actually see the difference when you use the seafoam
Old Oct 13, 2009 | 10:50 PM
hydrashocker's Avatar
hydrashocker
Yes!
Also make sure there isn't any fluids leaking on the harness of the O2 sensor and check the connections at the harness.
Old Oct 13, 2009 | 11:16 PM
teamdynasty1
when the light came on i pulled the clip off to make sure it was clean it did have an oil residue on it so i sprayed it with some elec cleaner and nothing changed do you think it shorted out?
Old Oct 13, 2009 | 11:22 PM
hydrashocker
Yes!
Thats a classic!
Old Oct 13, 2009 | 11:43 PM
teamdynasty1
sounds good thanks a lot
