Oct 18, 2009 | 08:09 PM
Hi, havent posted in a while. Just had a new battery put in my 02 Durango. A few hours later my chk engine light is on. Code is P0132 1/1 025 shorted to voltage. Whatever that is. Everything seems to run normal. Is the code there because a new battery has been installed and will reset by it self eventually? Or is something wrong? Thankyou for any input.
Reply 0
Oct 19, 2009 | 04:50 PM
P0132 1/1 O2S Shorted To Voltage
It's an O2 sensor. Looks like the upstream one,......AKA.....Before the Catalytic Converter. You might need a tune up.
What year, motor, and is it 4X4?
First do a PCM Reset. Look at the 1st post at the top for instuctions here: Engine Code Index (Check Engine Light?)
Reply 0
Oct 20, 2009 | 11:45 PM
hydrashocker
Remember on an older post, someone had a problem with their 02 sensors. After many post, we came up with power steering switch was leaking on a 4.7L engine. that was pushing P/S fluid thru the harness and up to the PCM. The P/S fluid was shorting out the 02 sensors.
Reply 0
Oct 21, 2009 | 02:09 PM
Ya,
Was that just he 4.7L?
Reply 0
Oct 21, 2009 | 03:49 PM
i could also just be you got water in the harness, i had that problem back in june when it rained 8 out of every 7 days, driving thru all the puddles and rain must have gotten water in the harness (no it was not possible to avoid the puddles) i cleared the codes and they never came back, you could try that and hope for the best (best of all this is free to try)
Reply 0
Oct 21, 2009 | 08:17 PM
Sure it could have gotten water in the connectors, But they should be sealed. I think the member live in reno,nv that replaced all 02 sensors two times before we nailed down the problem to the P/S switch. But i don't where mack24 lives either. The engine was a 4.7L .
Reply 0
Oct 21, 2009 | 10:59 PM
I can't steer around mud holes either......I feel your pain!....
Reply 0
Subscribe
