Durango Oil Filler TSB
Hey Gang,
I purchased the following items in TSB 090100A
53032126AA Baffle, Oil Fill Housing
53032389AC Cap, Oil Fill Housing
The Oil Fill Cap look just like the old one. Not for sure what difference there is.
The other item looks like you might put it in the oil filler neck. Not for sure what it does though. I have attached a picture. Any thoughts would be appreciated.
![](http://homehealthforms.com/images/misc/d1.jpg)
![](http://homehealthforms.com/images/misc/d2.jpg)
Trent
Trent
it allows the "snot"(as i call it) to sit on top of that instead of being sucked back into the engine (im assuming you have a 4.7l in your rig) and you might need a different cap to fit on after you put that piece into the filler neck, if i was home id take a picture of mine for you, after you put that in (not sure if you have it now or not) you will most likely notice a white build up on it and ont he bottom of the oil cap when you change the oil in the winter, that piece must just be in order to stop it from being mixed back in with the oil,
p.s. i only get the build up in the winter ymmv
