I cant find these parts!! help please
Old Nov 1, 2009 | 10:48 PM
jjhalo's Avatar
jjhalo
Default I cant find these parts!! help please
I need to replace the door lock actuators on both front doors. I have looked all over for this part but can't find it. They are for a 2001 4.7l D.
Old Nov 1, 2009 | 11:10 PM
IndyDurango's Avatar
IndyDurango
Dodgeparts.com
If you have the part numbers, it's even easier.
Old Nov 1, 2009 | 11:21 PM
jjhalo's Avatar
jjhalo
I checked there but I couldnt find anything.
Old Nov 2, 2009 | 12:33 AM
IndyDurango
They have them. As do all dealerships. What part numbers are you using?
IndyD
Old Nov 2, 2009 | 02:15 AM
rzramon's Avatar
rzramon
Hi Friend,
I think , i found the good one for you. Please refer to the below link.
http://www.slickcar.com/productdetai...?ProductID=552
Please revert for the same.
Regards,
Razor
Old Nov 2, 2009 | 02:35 AM
IndyDurango
Thanks Ramon. Unfortunately, those won't work.
jjhalo, here are my threads for replacement on the drivers front (PITA) and the drivers rear (EASY)
Locks Squealing
Locks Squealing - Part Deux
Assuming the part numbers you are looking for are the same, there are numbers in the threads.
HTH,
IndyD
Old Nov 2, 2009 | 11:52 AM
jjhalo's Avatar
jjhalo
not sure what the part numbers are I'll have to check. And its not that the locks make a noise, they just dont work all together. The front drivers side door will not lock, the alarm still works but it will not lock, and the front passenger side door will not open from the outside.
Old Nov 2, 2009 | 10:59 PM
IndyDurango
It is the actuators. Just replace them. Part numbers are in my threads.
Old Nov 9, 2009 | 09:37 PM
jjhalo's Avatar
jjhalo
Ok, I FINALLY found both lock actuators online, should be in this week! thanks for all the help.
Old Nov 9, 2009 | 10:42 PM
IndyDurango
Front door took me 2 1/2 hours. Rear door only 15 minutes after doing the front. My threads above have a lot of hints and tips. Good luck. Let us know how it goes.
IndyDurango
