Blinking D
Old Nov 10, 2009 | 09:59 PM
camarochris's Avatar
camarochris
Default Blinking D
I have searched all over and yet to find an answer.
2001 Durango r/t 5.9 4x4
the D indicator on the steering colum, the circle that goes around the d blinks when im on the highway for some reason. everything seem ok though
Old Nov 10, 2009 | 10:03 PM
brad8266's Avatar
brad8266
Does the truck actually shift into overdrive on the highway when at cruise? You could be stuck in 3rd instread of shifting into overdrive. Just a guess
Old Nov 11, 2009 | 07:44 PM
camarochris
Default blinking D
yes it shifts into overdrive, and runs through all the gears just fine.
Old Nov 11, 2009 | 08:30 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Go to autozone to pull codes (usually free) as your transmission may have a bad sensor or worse as this link suggests:
http://www.automotiveforums.com/t147...nnoying__.html
FF
Old Nov 15, 2009 | 11:02 AM
camarochris
Ok let me clear this up. the circle around the D blinks when I accellerate over like 65mph and races from P N R D 1 2, I checked the fluid and it all where it should be. I have never owned a dodge before so im not sure what it could be. and what i found on the net is not really helpful. Thank you any info would be appreciated thanks
Old Nov 15, 2009 | 02:01 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
are you sure that you have the gearshift selector locked into the D position? it should click and settle in if you push the lever towards the dash did you try doing a fluid/filter change? that might help, the other possibility could be a bad connection for the selector light
Old Nov 26, 2009 | 06:48 PM
camarochris
yes its locked in drive. what i recently noticed is that it only does it when it hot outside
Old Nov 27, 2009 | 01:40 AM
rebelboy's Avatar
rebelboy
me thinks bad sensor oooooooooooooor a ghost......... creepy
Old Nov 27, 2009 | 01:42 AM
Dans01Durango's Avatar
Dans01Durango
Neutral safety switch?... Just a thought.
Old Nov 27, 2009 | 10:37 PM
hydrashocker's Avatar
hydrashocker
Could be a Transmission Control Module going out. It is located by the passenger side head light under the hood. I think you should be good to go to a bone yard to pick one up.
