what causes a weak engine start?
Old Dec 15, 2009 | 12:21 AM
mrwilliwizard's Avatar
mrwilliwizard
Default what causes a weak engine start?
my 4.7l engine usually always starts really strong with no problems! one healthy S.O.B. but sometimes it will start kind of weak. the engine will turn on but it will stumble slowly like its about to stall but then it picks up and everything is fine. would this be the cause of old spark plugs? im changing them next week anyways but im wondering if that could be the problem. the plugs probably have about 30k on them :/. what other things might cause a weak start? and sometimes when i drive around and turn off the engine to go to the store or something and i come back and turn the key, the engine will start up strong in like less then a second of cranking. whats up with that? is it just cause the engines hot so it starts up quick? It's like right when you hear the sound of the electric motor, a fraction of a second after turning the key the engine starts lol. thanks.
sorry for grammer etc. im on my phone :/
Old Dec 15, 2009 | 01:20 AM
hydrashocker's Avatar
hydrashocker
1. Replace spark plugs with Champion Copper or Champion Truck plugs.
2. As for the quick start. You truck still has oil residue on the cylinder walls and a warm cylinder so starting when warm is a breeze.
Old Dec 15, 2009 | 07:36 AM
Duranged408's Avatar
Duranged408
Whats your CCA CA on the batt?
Old Dec 15, 2009 | 06:36 PM
mrwilliwizard
cca ca ?
Old Dec 15, 2009 | 07:37 PM
THEBIGSITT's Avatar
THEBIGSITT
Ironically, I was logging on to start a thread about the same problem. How hard of a job is swapping spark plugs?
Old Dec 16, 2009 | 12:15 AM
hydrashocker
CCA = Cold Cranking Amp's
CA = Cranking Amp's
Spark plugs aren't hard but what motor?
Old Dec 16, 2009 | 06:42 AM
Duranged408
looking at past posts big has a 5.9 ( you might want to put that in your sig/vehicle infor big)
Old Dec 24, 2009 | 09:25 PM
THEBIGSITT's Avatar
THEBIGSITT
Yeah I've got the 5.9. I'm thinking about replacing the spark plugs and MAYBE the fuel injectors over Christmas break. Anybody done either of these?
Old Dec 24, 2009 | 10:35 PM
hydrashocker
Go get Champion Truck Plugs at NAPA. Gap em at .040
Don't do the injectors unless you need to.
Old Dec 25, 2009 | 01:42 AM
rebelboy's Avatar
rebelboy
injectors are not nessassary chryler had no issues with these injectors and +1 cca how olds your battery
